7020 hydraulics
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Topic: 7020 hydraulics
    Posted: 01 Sep 2016 at 9:26pm
I was using my 7020 yesterday to haul silage yesterday with a Miller pro hydraulic rear unload wagon, it ran the conveyor no problem empty but wouldn't move it or very little once loaded with silage. What should I be checking, everything else was working fine, what kind of pressures should it have?
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Alex (wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex (wi) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2016 at 9:41pm
When is the last time the hydraulic filters in the transaxle housing were changed?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2016 at 9:52pm
There is a T fitting on PTO valve with a cap on it. Hook a 5000 lb gauge to the fitting. Pull one of the remote levers with nothing hooked to it. Gauge should read at least 2300 PSI.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2016 at 10:18pm
All the filters and oils have been changed
This page was generated in 0.075 seconds.
