7020 head gasket
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: 7020 head gasket
    Posted: 28 Sep 2018 at 9:28pm
I have 500 hours on a overhaul on my 7020 and it’s seeping a little engine oil out the left around the head gasket. I didn’t retorque like I should have, but is it too late? Just lack of bolts on the outside edge of the pushrods?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2018 at 10:27pm
The result will be 50%/50%. It will either work or it won't.  Loosen each bolt maybe 1/4 turn first and then torque back up to 165 ft lbs.
Big Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Orange Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 10:55am
Remove each head bolt one at a time, coat each bolt thread & top under the head with neverseeze, retorque bolts, check the torgue wrench for accuracy.  GOOD LUCK
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2018 at 9:27am
How'd it turn out? Did you re-torque or remove/never-seeze each bolt?
8070220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070220 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2018 at 5:50pm
U always get them up to time and retorque them .we torque all our to 175 .u shour it head gasket and not the turbo sucking oil and come out intake .
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2018 at 7:44pm
I just pulled it in the shop to do it. Resealing the steering cylinder and going to probably back them out a little and retorque the head. It is seeping right along the intake manifold, but I did put a new turbo on with the overhaul. The valve cover gasket is dry too. I’ve never had one leak before, but I did use a reliance gasket and I’m wondering if I should have used a agco even though agco doesn’t make it I’m sure. Does anyone use aluminum paint anymore?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2018 at 10:36pm
I would pull intake manifold to make sure there is no oil in manifold.    MACK
