7020 engine problem
AC-Farms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC-Farms Quote  Post ReplyReply Direct Link To This Post Topic: 7020 engine problem
    Posted: 28 Mar 2011 at 6:17pm
Hi, I am a fairly new forum member, but have been a frequent reader for a long time.  My family and I still use quite a few AC's in our farming operation and know this is a great source for info.  We have recently acquired a 7020 that has a miss in it.  The pan is over full with diesel, and the top of the exhaust pipe is very wet, too.  It doesn't seem to have much blow-by, but not knowing the history we haven't run it much.  Someone told us it probably has a hole in a piston, but we're not sure?  We were thinking of pulling the injectors and get them checked, and from there possibly the head?  I was wondering if any of you had any advice or things to look for.  Sorry for the long post, and thanks in advance for any advice,  Kevin.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 7:08pm
Could possibly be the shaft seals for the injection pump letting the fuel get into the pan, but that would not account for the miss.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 7:37pm
I bet you have a brocken spring in an injector, allowing the pop pressure to be very low, if at all.  You need to get this fixed asap, as you are washing the cylinder liner with fuel, and causing big time wear on the walls.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 8:19pm
That sounds right !!! Check them injectors , crack each imput line and see which one doesnt make a difference in the miss and you,ll have it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 8:27pm
I finished reading your post, if you have a burnt through piston, it will have severe blow by, and I don't think you would get much out the stack.  get that oil drained asap as well, since the bearings can tolerate some but not a full pan worth.
Edited by Orange Blood - 28 Mar 2011 at 8:29pm
Still in use:
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 8:54pm
Tip blown off a injector do to water in fuel.   MACK
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 9:56pm
Mack, Just curious, how much more would water compress then fuel in a injection system?
Allis Express participant
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 11:17pm
The problem is when water in fuel hits the hot injector tip,it turns to steam and blows the tip off.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2011 at 6:43am
Water willnot break down small enough to go through tip.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2011 at 9:06am
And it also has no lubricating properties...
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC-Farms Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2011 at 11:15pm
Thanks for the advice, hopefully we'll get time to look at the injectors this weekend.  Kevin
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2011 at 11:56pm
My 7060 has blown holes in a piston twice and when it does it you have alot of blowby and it smokes like a freight train.
