7020 coolant lines? |
Blustery Knoll Farm ![]() Bronze Level ![]() Joined: 04 Dec 2017 Location: Northern IL Points: 117 |
![]() ![]() ![]() ![]() ![]() Posted: 29 Jan 2018 at 7:30pm |
What seals the steel coolant lines that connect to the oil cooler? I tightened the nuts and the leak didn't stop. I loosened the nut to see if it was a cracked flared end, but it's not a flare fitting. I only found a few pieces of rubber chunks inside the nut. Is it a rubber compression washer?
Related question. What's the proper coolant to use? If I drain it, I might as well put in new. |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8593 |
Rubber chunk.Looks like a very short piece of hose. Do like Doc says and put in Cat extended life coolant.
Is that a dealer part?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21795 |
Yes, get it from an AGCO dealership. What ever happened to your engine HP complaint ???
Thanks. I haven't dealt with that yet. My local independent mechanic told me to drive it to his shop and run it on the dyno, but I've not had a chance to get it up there yet. It's either been way too cold, then it gets foggy when it warms up. Neither being good for a 25 mile tractor drive. Hoping to get it up there next week.
