7020 Clutch
7020 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7020 Quote  Post ReplyReply Direct Link To This Post Topic: 7020 Clutch
    Posted: 13 Dec 2017 at 9:02pm
I am new to the Allis "world" and just found this forum and I'm hoping you all can help. I recently bought this 7020 through an online auction. I'm going to put a loader on it and then mainly use it on a sationary grain cart. The problem is that the clutch pedal is very hard to push and whether cold or warmed up, it will not "hold" it in first gear and gears grind shifting into all positions. Do I need a clutch? If so, may just cut my losses before it gets expensive. Thanks.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2017 at 9:47pm
I would say it needs a new clutch cable, then adjusted.
To adjust, with engine off, pull cable toward engine until all free travel is out of clutch pedal then tighten clamp. May need readjusted later with new cable. No throw out bearing so keep all free travel out of clutch with engine off.
You will like the 7020. Glad you found this sight.    MACK
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2017 at 6:21am
What do you mean it won't hold it in first gear? It pops out of gear or you can't shift into first? On my 7050, when I first got it, it had a very stiff clutch pedal and wouldn't shift without grinding and it was almost impossible to shift it into first gear when running. It wasn't long and the cable broke. It was the cable as MACK said. On my brother's 7030, his was also got hard to shift into gear without grinding but the clutch pedal wasn't stiff. I tried adjusting the cable as MACK suggested to you but on the 7030 that did no good. Then I took a look at the bushings in the pivot linkage and although they really didn't look too bad I replaced them and it's work great ever since. We love both tractors and they have been a part of the farm for nearly 20 years.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2017 at 9:37am
The "clutch" is a hydraulic clutch pack,not a conventional dry disc,pressure plate,throw out brg. You are moving a valve.There is also a hyd trans brake to stop gears turning.Everything has to be adjusted correctly to make it work right. The cable is usually the first culprit. You really could use a manual for procedure.
7020 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7020 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2017 at 9:58am
Thanks for the responses. When I say it doesn't hold it in first, I mean with the clutch pedal pressed to the floor the tractor is still trying to move forward in first gear.
Where is the best online source for manuals or parts? Thanks
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2017 at 10:11am
It sounds like a bad cable
Local AGCO dealer for parts and manuals or Sandy Lake or other sponsors of this site.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2017 at 10:12am
Could possibly be warped plates too that cause it to creep but I'm guessing cable
Wink
I am a Russian Bot
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2017 at 12:04pm
$144 cable at my dealer. I just replaced it on my 7020 3 days ago. Mine was really stiff and made backing up to impliments difficult.
Edited by 7060 - 14 Dec 2017 at 12:06pm
7020 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7020 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2017 at 11:57am
Thanks,
Since I don't have a local dealer I'm checking in to ordering a cable and manuel online.
Another problem has developed which could be related or not. There are six warning lights on the dash behind the steering wheel. The cover is missing so I'm not sure what they represent. The light at the lower right corner lights up at low idel. What are these lights monoriting? Like I said, I have not gotten a manuel ordered yet.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2017 at 6:13pm
What part of OK are you from? Livingston should be able to order anything you need.
If they are too far out, site sponsor Sandy Lake Implement can ship direct to your door.
Check out agcopartsbooks.com to get part numbers of what you need.
They also sell that little faceplate for the warning lights seperately, so you can buy that as well.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
lentsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2017 at 7:38pm
I will try to help with the warning light part of your question. My 7000 has 8 "squares". Bottom 2 are not used. Left side starting on top is alt., engine oil and trans oil temp. Right side starting on top is turn sig. ind., not used and trans oil pressure. Trans oil pressure blinking at idle is normal-book says should be out by 1800 RPM-mine goes out long before that. Hope this helps.
WD,D15,190XT,7000,8010x2,7060,8070
7020 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7020 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2017 at 9:42pm
Yes it does. Thanks I appreciate the help.
