7020 back to work |
BillinAlberta
Joined: 12 Sep 2009 Location: Saskatchewan Points: 357 |
Thanks(1)
Topic: 7020 back to workPosted: 16 Nov 2023 at 4:17pm |
Hydraulics working and engine running smooth.Thanks for the help and advice!
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7539 |
Posted: 16 Nov 2023 at 4:24pm |
Interesting choice of engine.
DougG
Posted: 16 Nov 2023 at 5:44pm |
Interesting indeed, but the AC 292 gasser is rated for 94 hp on a Gleaner F,,
BillinAlberta
Posted: 16 Nov 2023 at 6:10pm |
It is a 301 from a model G Gleaner.Seems to make a dandy baler and bush hog (7foot) tractor. Power shift works well. The cultivator is 11 ft modified to 3 point. Pulls fine. The original engine was needing too many dollars and I had this in the shed already.Surprisingly easy to bolt in . |
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3582 |
Posted: 16 Nov 2023 at 6:41pm |
It’s still all AC, but very unique. Thanks for sharing. It is probably a great winter/chore tractor ~ starts easily when cold? So do you call is a 7020G ?
Edited by AC7060IL - 16 Nov 2023 at 6:43pm |
Unit3
Posted: 16 Nov 2023 at 6:52pm |
Is it the same as a 190 gas?
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3952 |
Posted: 16 Nov 2023 at 7:23pm |
i am thinking about putting one of those 301 gas out of a 190lpg in my d17 if i dont soon find stuff to overhaul my 262d
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5124 |
Posted: 16 Nov 2023 at 7:34pm |
I'm a diesel guy, but that is actually pretty dang cool! It makes sense in your climate! Probably way short of what a 7020 could originally do though, but it's purpose built, so go for it! Pretty thirsty?
Posted: 16 Nov 2023 at 7:45pm |
190XT had the G-2800/301 gas at 105 flywheel HP, which should be about 80 PTO HP in a 7020 chassis. If it is from a 190 it is the G2500/265 cubic inch version at 12 less HP than the 301.
Edited by DrAllis - 16 Nov 2023 at 10:19pm |
HudCo
Posted: 16 Nov 2023 at 9:10pm |
i forgot to say xt but that engine really does fit very clean looking in that 7020
Unit3
Posted: 16 Nov 2023 at 10:53pm |
I don’t know if it’s a crop hustler or a land handler, but it sure is a clean build. It would only happen to me, but after all of the years of putting diesel in it, I would sometime forget and put diesel back in. Beautiful tractor.
Ron(AB)
Posted: 17 Nov 2023 at 12:00am |
Improvise, adapt, overcome!
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Posted: 17 Nov 2023 at 1:31am |
Easy swap. 7020 flywheel and backplate, maybe (maybe not) the 7020 water pump, fabricate front motor mount brackets to the side frames, and an air cleaner connection to the carburetor.
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8735 |
Posted: 17 Nov 2023 at 6:24am |
Sometimes you have to think outside the box. All things considered, it could be a game changer in cold climate. Every time that I put gas into my thirsty 190, I contemplate getting rid of it. But then anytime it's cold and I don't have any other tractor plugged in, it's nice to have. Darrel
injpumpEd
Posted: 17 Nov 2023 at 7:30am |
Now just put EFI on it, like the guy from Walnut here that makes up kits for gas 3020/4020's. Would make for a really nice chore tractor in the cold!
DSeries4
Posted: 17 Nov 2023 at 10:17pm |
The 292 in the Gleaner F is a GM engine, not AC.
DougG
Posted: 18 Nov 2023 at 5:26am |
Yup I was wrong the gasser in an F - was Allis 262,, knew it was something like that, when they run good they put out the power
GM Guy
Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1985 |
Posted: 25 Nov 2023 at 4:47pm |
I still think there is a place for gas on the farm, EFI and turbocharged especially.
I may be crazy, but I think the new holland bi-directional would still sell if they mad a gas version, seems a common use for them is moving round bales around in winter for many plains cattle ranches, and EFI gas would definitely go over good in that application, especially if the price reflected it. |
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
AC7060IL
Posted: 27 Nov 2023 at 6:37am |
1. G2800, Power-Crater gasoline rated @ 102hp, 301, or 2. G2800, LPG 95hp 301 or 3. 2900, turbo diesel 104hp 301. From what I gather, the 68' & 69' gleaner G/GH gas may have been the ONLY gleaners with the G2800 engines? From 1970-72, the G gleaners G2800s were replaced by the gm 350 v8 which then became standard in the 1973-76 Gleaner M/MH/Hillside gas. In Norm's book's "engine & power unit" section, it mentions that the gleaner F, along with the 190XT were offered with a G2800. The AC 2800 diesel was offered in the F. But, my 1968 (6711 dated, 67'Nov) gleaner F sales literature only list the 262s gas & LPG. Guess maybe a late 68' or 69' F could have also used a G2800 version~80ish hp? Anyone have a 1969 year Gleaner F sales literature to verify one way or another? In 1970, the F was then offered with the gm 292. Your 7020 gas is unique & very cool. Edited by AC7060IL - 27 Nov 2023 at 12:37pm |
dchilton
Posted: 27 Nov 2023 at 10:04pm |
You done a nice job on it. Looks great.
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3539 |
Posted: 15 Apr 2024 at 9:54am |
Did you find a tractor gov and control ?
BillinAlberta
Posted: 15 Apr 2024 at 1:34pm |
I am using the governor and throttle levers direct from the combine.It may be useful later to modify the governor for better mid range speed control.Right now it works fine.
Posted: 15 Apr 2024 at 1:41pm |
Gleaner model "F" combines had G-262 (early) and GM-292 gas engines...NEVER a G-2800. Model "F" used D-2800 diesel engines. Only the early model "G" Gleaners had the G-2800 engine and then they went GM-350. Gleaner "G"'s always had D-2900 turbo diesels.
tbran
Posted: 15 Apr 2024 at 2:22pm |
Yes, the 190 gov would be an asset - unless you have it wide open - you have no gov now...
