7010 starter swap with 190xt?
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Topic: 7010 starter swap with 190xt?
    Posted: 02 Jul 2025 at 10:54pm
My solenoid has gone out and I can't get one until Saturday or Monday. According to specs on some starters the 190xt could work in a 7010. Has anyone done this and is it possible? I have a lucas starter in 7010, but not sure of 190xt. The length of the motor is larger on 190xt versus 7010. I looked at my 7020 and it appears to be the larger version of the starter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2025 at 6:21am
Lucas (short) starter fits everything. Delco (long) starter could have interference on some engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2025 at 10:29pm
I can confirm the delco from 190xt will not work on a 7010. The fuel filter housing bracket is in the way. You could install it cockeyed but the fuel line below does not line up. The throttle cable also would be a problem. If the 190xt had lucas starter, it would work. I had to have a new lucas fedexed at great cost. Agco does not sell new ones. They are available though.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2025 at 2:44pm
 Nippon Denso #028000-6780   GEAR REDUCTION STARTER ACR0513480 AGCO PN
This page was generated in 0.320 seconds.
