7010 PD doesn't want to go into low range
Roscoe62 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Topic: 7010 PD doesn't want to go into low range
    Posted: 12 Dec 2016 at 11:59am
My 7010 PD won't go in to low range.  Just stays in neutral.  Sometimes by shifting a bunch between High and Low, it will finally catch.
Is this a cable problem, and is there an adjustment?
Thanks,
Roscoe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2016 at 12:06pm
Probably the small side-shift cable is stiff/sticking. Adjust all you want, but replace the cable first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2016 at 12:12pm
And I just put the floor plate back on a few weeks ago.....
I don't have a parts book for this.  Can I find the part number on-line somewhere?
Thanks,
Roscoe
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2016 at 12:15pm
agco partsbooks online, sign in as a guest, and see everything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2016 at 12:44pm
That did it!  By the small side cable, I assume that is the one on the bottom of the shifter?
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2016 at 6:30pm
Yes.
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2016 at 6:44pm
my heim joint split.   got mine back together and welded it.   cleaned threads and it works like new.   pull the floor pan, it will tell u the story
AC from the start of my families farming career till the end!
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2016 at 1:35pm
I ended up cutting a hole in the floor plate and installed a shift lever for my 7010.
