7010 New Temp Gauge / New Sensor
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Topic: 7010 New Temp Gauge / New Sensor
    Posted: 05 May 2025 at 9:08pm
I also tested my temp gauge and new sensor.  I think at most the gauge could be off by about 15-20 degrees.  I used a Laser based thermometer and pointed it at the sensor end.  After running for 5 minutes, it showed 136 degrees.  Based upon my estimate on the Gauge it was reading around 140-150.  Hard to estimate it exactly.  Good news is that I don't have to calibrate the Temp Sensor and Gauge.  Later this summer, I will use my laser thermometer and figure out differences.  It is not unusual for engine to get to 210 or so in 95 degree day.
I understand that if I need to dial in the temp, I will have to use additional resistors in parallel to lower the resistance.  We will see.  Right now, I am going to avoid the calibration step for the engine temp.
So, looks like the new combo gauge for temp/fuel is going to work out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2025 at 9:20pm
I would say your temp gauge is spot on. Using an infant red point-and-shoot temp reader gun would surely be a little bit less on the outside of the thermostat housing (or wherever you are pointing to) than directly sensing in the coolant itself.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2025 at 1:57am
What kinda set of gauges did you pick up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2025 at 7:28am
The gauge came from Agco.  It is a perfect match to the original factory gauge on the looks side.  The posts on the back are completely different.  Old gauge appears to have resistors built into the gauge.  It is not that way on the new one.  I hope I don't have to calibrate but we will see in about a month once hay season gets going.
Dave7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave7060 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2025 at 9:16pm
The new temp/fuel gauge units from Agco for the 7/8000 series tractors are exactly the same as the aftermarket replacements. As soon as an aftermarket became available that's who Agco got to supply them too. They do not read temperature accurately and they are poor quality, I had three that either went bad prematurely or didn't work correctly right out of the box. Found a NOS Agco replacement that has the gauges side by side not top and bottom and has worked correctly since. New sender and wire between as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2025 at 3:49pm
I got a chance to run all of the fuel out of the tank this past week.  The Fuel gauge is pretty close on needle at empty and needle at full.  So, my extension of the fuel sender unit and the resistor have made it work like it should.
How long the gauge lasts is a different story but we will see.
You did indicate temp gauge isn't accurate from your tests.  After testing it, and thinking it was pretty close, then putting everything back together, the needle is failing to show the proper temperature or even move significantly after turning on the key (it does move slightly though).  I didn't feel like pulling the dash apart again but I will at some point.  Temp is more important anyway.  I am hoping it did not fail but it makes me wonder.
This page was generated in 0.037 seconds.
