7010 Low Idle Moving Issue |
calico190xt68
Joined: 12 Jan 2017 Location: Frankton, IN Points: 904 |
Topic: 7010 Low Idle Moving IssuePosted: 11 Aug 2022 at 4:29pm |
When I have the engine at lowest engine idle position and regardless of what gear I am in or whether the power director is in low or high, I have this problem where the tractor stops moving for a second or two, then it "catches" and starts moving again. Even on flat ground it does this. Once moving and I am still in low idle, it will do it repeatedly where it hesitates then catches and takes off. If I get the RPMs at 1800 or above, I have no problems. I don't seem to have a loss of power in high RPMs. If I am going down a hill, it will act like it is in neutral and run down the hill in low idle. Maybe I have lost some fluids somewhere that is causing this? I see hydraulic fluid in the sight glass. Hopefully it isn't bad things to come. Thanks in advanced for any ideas. |
DougG
Posted: 11 Aug 2022 at 6:02pm |
Id be checking the hydraulic fluid, filters and /or pressures- have heard the site glasses can get cloudy, jmo
Edited by DougG - 11 Aug 2022 at 6:03pm |
Posted: 11 Aug 2022 at 7:14pm |
Dipstick under the seat is LOW by 2 or more gallons !!!
MACK
Posted: 11 Aug 2022 at 9:33pm |
If not low on oil, pump is getting weak or PD needs resealed. MACK
calico190xt68
Posted: 12 Aug 2022 at 8:56am |
Thanks everyone. Dr is right. It is low. I will figure out how low once I fill it a quart at a time. I probably should drain it and start fresh but it will take a few days to get a new filter and I have hay to make. When I checked it beginning of season, I thought it was fine. It calls for 821 Fluid so I am going to use a universal trans-hydraulic fluid. i will get it working correctly. I got to looking and I do have some oil around the bottom of tractor but I thought it was a result of my prior hydraulic leaks under the cab that is now fixed. I am going to have to power wash everything and figure out the source of the leak. Thanks for the opinions. I will report back once I get the fluid filled.
calico190xt68
Posted: 13 Aug 2022 at 6:42pm |
It was low by about 1.75 gallons so close to 2 gallons low. Don't know if it has a leak or not yet. I am guessing if it has a leak that is a bigger problem. Hoping it is just normal loss of fluid, but not sure on expectations of normal loss of fluid each year. We have used it much more this year than ever before so that might be a reason why it has more loss. Will continue to check the dipstick although the fluid is so clear it is hard to see. Make's me wonder if my eyesight failed at the beginning of the season when I checked it. Problem has gone away so thanks! I should have known better and checked it when my son reported it to me rather than posting first. :-)
