7010 Injector replacement
roscoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roscoe Quote  Post ReplyReply Direct Link To This Post Topic: 7010 Injector replacement
    Posted: 13 Apr 2011 at 6:58am
I'm getting ready to replace the injectors on my 7010.  Are there o-rings on the injectors?
The new ones have a groove about half way down, looks like it could be for an o-ring.  I do not see o-rings in the packages of injectors.
Anyone know where I can get these, and maybe a part number?
Thanks,
Roscoe.
niel ev View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote niel ev Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2011 at 8:35am
No orings are needed the injectors should seal to the tubes in the head Niel
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2011 at 9:13am
Drain the antifreeze before removing the Injectors.There is a copper seat / tube that seals the injector
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2011 at 9:46am
BECAREFULL, the copper tubes are swedged in the head.  Gently wiggle, tap add pentatration oil etc to loosen - DO NOT force out if stuck.  Removal of copper sleeve = $$$$$$$  -  Clean the head, loosen the retaining bolts and retainer and gently move the injectors back and forth - there is a injector removal tool - but I hate to use it as a stuck injector will be removed along with the copper sleeve.   No seals at the bottom or orings, there is a rubber dust shield around the top.  - pick up a bolt for the drip line and the little sasher seals  as you may pop a bolt when tightening - new ones are not hollow and thus stronger - they do not have to be super tight to avoid leaking  as the drip line is 0 pressure.
This page was generated in 0.695 seconds.
