7010 injector pump
farmboycitygirl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboycitygirl Quote  Post ReplyReply Direct Link To This Post Topic: 7010 injector pump
    Posted: 15 Oct 2024 at 6:49pm
Our 7010s injector pump managed to come apart (literally).  We have another running engine out of a combine however the injector pump is an inline not the circular rosa master.  It has Minimec pump (that what the pump says anyway.  My question is will this injector pump replace our existing 7010 rosa master pump if we can change the pump what needs to be done or should we replace the entire engine with the combine engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2024 at 7:00pm
I don't know what has failed in your injection pump, but I would never advise swapping a (good?) running engine for some 10 year older and unknown condition combine engine. Fix your pump or buy a used pump from a salvage yard and have it freshened up. A pump from a 7000-7010-7020 or M2/M3 combine will fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2024 at 6:27am
From a labor standpoint, an injection pump swap is a couple of hours and takes minimal tools. An engine swap from a combine ?? waaaay more labor than you can imagine by comparison.
Edited by DrAllis - 16 Oct 2024 at 6:28am
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2024 at 8:01am
I cannot imagine how bad a Roosa DM could fail to make swapping the entire fuel system or even engine over to get it going. Sometimes you just have to bite the bullet and call in a professional lmao! Most pump shops have good cores to scavenge parts from to make one run again!
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2024 at 5:59am
I'm no expert, but will chime in. Mostly curious as to what could have possibly happened to your roosa pump to make it unrepairable? I do know for certain that getting a roosa back on there, whether it's having yours repaired by a good pump shop, or finding a different one like it, will definitely be best route to go, like Dr and Ed said.
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2024 at 8:23am
Seems like I remember this tractor having hard starting issues some time back and pump timing was in question. I thought the pump had been just gone thru at that time ?? Maybe not.
Straanger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Straanger Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2024 at 10:53am
“Managed to come apart (literally)”.
Sounds like something that should be explained. Preferably with pictures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboycitygirl Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2024 at 7:07pm
something came loose and punched a hole in the case.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboycitygirl Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2024 at 7:10pm
Yes DR it is the same tractor - we had the pump rebuilt by ST Joe diesel in St Joe MO.  The warranty was only a year so we got a used pump and that one is the one that flew a part.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2024 at 8:30pm
still dont think i would change out the engine just for a bad pump un less you think their is somthing wrong with accessory drive
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2024 at 8:55am
possibly could use both pumps to build one good one again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2024 at 3:42pm
well, I got the St Jo pump in and apart, sadly the head is seized. The leaf spring screws had backed out quite a ways(had to be really low on hp) to the point one of them began hitting the lobes of the cam ring. So with any internal unhappiness, they end up seizing up. It looks like the cam ring had been replaced as well as the head and rotor being a rebuilt one by the looks of things. The DM pumps use shoes that are .005" difference in sizes, and a lo hp app like a 7010 would use -020 shoes, that keeps the leaf spring screws in most of the way letting their nylok patch hold them in place. Well, this one has new looking -015 shoes so in order to close down the roller setting the leaf spring screws would be out further, therefore allowing them to simply back out. I texted Gary some pics, so hopefully he can post them up, I am not smart enough lmao! Sad to see the poor work coming out of the big shops, and they won't back it. This had to be making horrendous racket while the screw was hitting the cam lobes, could have saved the head if it would have been parked and pulled off before catastrophic failure. Looked closer and it has -010 shoes which is even worse. Almost like they only want to stock the one size. The leaf spring screws are loose, the one that hit the lobes turns with my fingers.
Edited by injpumpEd - 11 Nov 2024 at 7:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2024 at 3:49pm
To quote Mr. Spock:   "interesting"..................
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2024 at 6:33pm
Ed, I just want to say thank you for posting up what happened.  I have been misled by so many injection pump shops in my life.  I really appreciate that you are honest on here and give proper advice.  I sure wish you lived close enough to me I could drive up to your door with my pumps and injectors.
Its hard to have faith in shops when you post that they used the wrong parts and that they assembled it so the screws could come loose.  Almost makes a guy wonder if it was the first one they ever worked on and they never read the spec sheet how to assemble
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboycitygirl Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2024 at 8:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboycitygirl Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2024 at 8:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboycitygirl Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2024 at 8:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboycitygirl Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2024 at 8:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2024 at 8:48am
Thanks Gary for getting the pics up. Hopefully your other pump that flew apart will have a good head & rotor in it. I have a new h&r in stock and warehouse has several too, but the $1600 price tag stings! There's lots of these DM pumps around to steal parts out of yet.
You can see the screw is worn down on top, and the notch in the center of the cam lobe is from it wearing on it. Any side load on the rotor will cause it to seize. This could possibly have been saved if it was noticed to be making more noise than normal. I'd never seen this before, so I would not have guessed this was happening.
Edited by injpumpEd - 12 Nov 2024 at 8:53am
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboycitygirl Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 2 minutes ago at 8:53am
We received the pump back from Ed Guenther (injpumpEd), very quick turn-around.  We installed on the tractor Wednesday  Everything we needed to reinstall the pump was included.  The pump looks brand new.   Thank you Ed.
Make a long story short the tractor runs great.
Thank you all for the help to get this tractor up and running again.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 9 minutes ago at 9:46am
I'm so glad we were able to get this back going without major issue, as the thread started out. Sadly you got bent over by sT jOe , must be the name jOe lmao! Thanks again for the opportunity to provide my services.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 45 minutes ago at 5:10pm
Use clean and quality fuel and change the fuel filter regularly and that injection pump will outlast the tractor.
