7010 hydraulic pump
wheelbilly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheelbilly Quote  Post ReplyReply Direct Link To This Post Topic: 7010 hydraulic pump
    Posted: 21 Nov 2016 at 9:05am
Looks like piston pump needs replacing or repairing   What expierence have you had with this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 9:14am
I can still count on one hand how many I've ever replaced. I've fixed more for broken springs and oil leaks. What's wrong with yours?? Infrequent oil and filter changes will contribute to a piston pump internal failure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheelbilly Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 9:23am
Just bought this tractor   No apparent flow at all
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 9:33am
You need to connect a 3,000 psi gauge to the tee on the PTO valve and see what the stand-by pressure is (if there is any) and go from there. If you want to just go ahead and swap a pump, have at it. The tractor moves and has power steering, right ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheelbilly Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 10:00am
tractor has no standby pressure at all.  how difficult is it to repair this pump?  Power steering works and tractor moves, just no remotes and 3 point does not work.  Just to repeat,  guage on pto valve doesn't show any pressure at all,  standby valve and high pressure valve in compensator are not stuck
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 10:05am
If low pressure standby and high pressure compensator spools are free AND their springs are not broken, I'd probably remove the pump and see if the swash plate spring isn't broken, which does happen once in a while. Before that, technically one should add some sort of shim to the low pressure compensator spool to force the pump into stroking up. If nothing happens when adding shims to the low pressure spool, there's something wrong inside the pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheelbilly Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 10:24am
Thanks Dr Allis  I have already shimmed up low pressure spool and got no response on standby pressure at all  Felt like pump problem might be next thing to consider   Your advice is greatly appreciated
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 10:53am
I always pulled out both belly filters first, disconnect and rotate the surge chamber line out of the way and plug it, seperate the piston pump and shove in one small plastic plug. It can sit like that for days and not lose any hyd or trans oil. Yellow 3M glue the new pump gasket in place (and let dry) and a thin film of RTV on the other side when going back together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheelbilly Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 5:01pm
Thanks for info   Will probably  be a few days  before I can get to  it
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 9:10pm
Agree with Dr. Have found squash plate piston come unscrewed on some .    MACK
This page was generated in 0.107 seconds.
