7010 engine overhaul |
HagerAC
Topic: 7010 engine overhaulPosted: 03 Dec 2025 at 10:52am |
My open station 7010 started dripping coolant out of the breather this summer and parked it after I noticed it. I'm not sure when it started but it wasn't this way when I had the valve cover off late last winter and have only put less than 10 hours on it in the spring Have since dug into it and found a leak coming from between the number 6 sleeve and block. It is tired and needs a freshening up anyway. Wondering about what kit to use. I did put an Absolute kit in my 190xt a few years ago and have been happy with it. Seemed like a good kit and would probably go that way again. I have also found a kit from Federal Power Products, wondering if anybody had any experience with this kit or not? I am not interested in a Reliance kit. Thanks
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3590 |
Posted: 03 Dec 2025 at 3:51pm |
Sounds like you need block work more than an engine kit. I would check sleeves for roundness and re ring if ok - you will have to do a close inspection to determine what is needed - you are going to have to spend the money sleeving the block bottom bores quite possibly and by all means re-bearing all.
Leon B MO
Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2218 |
Posted: 03 Dec 2025 at 4:00pm |
We rebuilt a 301 in our 200 January 2024. Used a Reliance kit from Agkits. Bought the gasket set from Agco. We were satisfied with the Reliance kit. Tractor starts and runs perfect. Gonna split an XT tomorrow for a rebuild. Plan to do it the same way. Sorry I couldn't be more helpful.
Leon B Mo |
Posted: 03 Dec 2025 at 6:01pm |
For best results, remove the oil pan FIRST and pressurize the cooling system to 100% absitively determine where the leak(s) are coming from before you rip it all apart.
SilverShoes
Joined: 20 Feb 2014 Location: Seneca, Kansas Points: 175 |
Posted: 03 Dec 2025 at 7:39pm |
I replaced my 7010 head because it had cracks around the injector sleeves. I used a 200 head because they didn’t have sleeved injectors. Could your leak be coming from the injector sleeves or head cracks?
HagerAC
Posted: 03 Dec 2025 at 8:53pm |
No it's from the bottom between the sleeve and the block on number 6. I had allready pulled the pan, pressurized the system and had the block heater plugged in yesterday and had a pretty steady drip.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8809 |
Posted: 03 Dec 2025 at 9:36pm |
Uncle had to sleeve the bottom bores on a 7020. 301 known for electrolisis down low.
HagerAC
Posted: 17 hours 5 minutes ago at 8:36am |
So I am in the process of putting this thing together. Got the sleeves in and main bearings in. Got rods and head back from machine shop a couple days ago. I did order new rod bolts and was assembling pistons to rods and putting new bearings etc. in rod. When I went to put the new rod bolts in I am having difficulty getting them to thread into the rods and they also do not want to fit through the caps very well. They will begin to thread in but then they get tight. The rod bolts I ordered from agco, but I don't like the way they fit and will probably just reuse the old bolts. Has anybody else had an issue with the rod bolts from agco. I believe they are sourced from ARP.
SteveM C/IL
Posted: 16 hours 15 minutes ago at 9:26am |
The ones for the 426 I have used have ARP stamped in them.
tbran
Posted: 15 hours 35 minutes ago at 10:06am |
301 Rod bolts 74024583 have never been an issue. The 426 were the ones changed to ARP many decades ago by request of the AC service department.
The new bolts should thread in by hand if the old ones will - otherwise I would not use them - Somethings wrong. There were two rods on the 301 - the old ones had 6 point and the 12 point bolts will not interchange w/o machining the old style rods - the old bolts are NLA.
HagerAC
Posted: 15 hours 8 minutes ago at 10:33am |
Yep that's the part # of the bolts, but they will not thread in maybe more than a few turns and they get tight. They will thread into a fine thread 3/8 nut just fine as will the old ones but not in the connecting rods.
Michael V (NM)
Posted: 14 hours 32 minutes ago at 11:09am |
hmmm,,, whatever ya do, I wouldn't re-use the old rod bolts. maybe get a NEW tap and die and run the threads on the bolts and rods... look into newer rod style that fits the new bolts?.?.. yea, I know,, more $$$ to spend,, but I really hate to see you open a window in the block after ya done all this work..
or maybe contact ARP and see if they have a solution....
Edited by Michael V (NM) - 14 hours 32 minutes ago at 11:09am |
Oldoug
Posted: 13 hours 5 minutes ago at 12:36pm |
Do your old rod bolts thread into the rods like they should...or is there something wrong with the rods after they came back from the shop?
Matt Folkers
FOLKERS RESTORATION Restoring vintage things to last so the future can enjoy our past. |
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5188 |
Posted: 11 hours 44 minutes ago at 1:57pm |
I've had to chase the threads in the rods, and also de-burr the holes in the cap to make sure they turn free without binding, throwing off the torque.
HagerAC
Posted: 6 hours 1 minutes ago at 7:40pm |
Old bolts go right in easy by hand and these are the new style rods which just got new pin bushings put in at the machine shop.
Edited by HagerAC - 5 hours 59 minutes ago at 7:42pm |
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2884 |
Posted: 5 hours 45 minutes ago at 7:56pm |
Not a Reliance kit.
orangereborn
Posted: 1 hour 18 minutes ago at 12:23am |
Ran into that problem sometime back and saved this sheet...Dale
