7010 engine overhaul
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Topic: 7010 engine overhaul
    Posted: 03 Dec 2025 at 10:52am
My open station 7010 started dripping coolant out of the breather this summer and parked it after I noticed it.  I'm not sure when it started but it wasn't this way when I had the valve cover off late last winter and have only put less than 10 hours on it in the spring Have since dug into it and found a leak coming from between the number 6 sleeve and block.  It is tired and needs a freshening up anyway.  Wondering about what kit to use.  I did put an Absolute kit in my 190xt a few years ago and have been happy with it.  Seemed like a good kit and would probably go that way again.  I have also found a kit from Federal Power Products, wondering if anybody had any experience with this kit or not?  I am not interested in a Reliance kit.  Thanks
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2025 at 3:51pm
Sounds like you need block work more than an engine kit. I would check sleeves for roundness and re ring if ok - you will have to do a close inspection to determine what is needed - you are going to have to spend the money sleeving the block bottom bores quite possibly and by all means re-bearing all.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2025 at 4:00pm
We rebuilt a 301 in our 200 January 2024. Used a Reliance kit from Agkits. Bought the gasket set from Agco. We were satisfied with the Reliance kit. Tractor starts and runs perfect. Gonna split an XT tomorrow for a rebuild. Plan to do it the same way. Sorry I couldn't be more helpful.
Leon B Mo
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2025 at 6:01pm
For best results, remove the oil pan FIRST and pressurize the cooling system to 100% absitively determine where the leak(s) are coming from before you rip it all apart.
SilverShoes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2025 at 7:39pm
I replaced my 7010 head because it had cracks around the injector sleeves. I used a 200 head because they didn’t have sleeved injectors. Could your leak be coming from the injector sleeves or head cracks?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2025 at 8:53pm
No it's from the bottom between the sleeve and the block on number 6. I had allready pulled the pan, pressurized the system and had the block heater plugged in yesterday and had a pretty steady drip.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2025 at 9:36pm
Uncle had to sleeve the bottom bores on a 7020. 301 known for electrolisis down low.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 25 minutes ago at 8:36am
So I am in the process of putting this thing together.  Got the sleeves in and main bearings in.  Got rods and head back from machine shop a couple days ago.  I did order new rod bolts and was assembling pistons to rods and putting new bearings etc. in rod.  When I went to put the new rod bolts in I am having difficulty getting them to thread into the rods and they also do not want to fit through the caps very well.  They will begin to thread in but then they get tight.  The rod bolts I ordered from agco, but I don't like the way they fit and will probably just reuse the old bolts.  Has anybody else had an issue with the rod bolts from agco.  I believe they are sourced from ARP.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 35 minutes ago at 9:26am
The ones for the 426 I have used have ARP stamped in them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 55 minutes ago at 10:06am
301 Rod bolts 74024583 have never been an issue. The 426 were the ones changed to ARP many decades ago by request of the AC service department.
The new bolts should thread in by hand if the old ones will - otherwise I would not use them - Somethings wrong. There were two rods on the 301 - the old ones had 6 point and the 12 point bolts will not interchange w/o machining the old style rods - the old bolts are NLA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 28 minutes ago at 10:33am
Yep that's the part # of the bolts, but they will not thread in maybe more than a few turns and they get tight.  They will thread into a fine thread 3/8 nut just fine as will the old ones but not in the connecting rods.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 52 minutes ago at 11:09am
hmmm,,, whatever ya do, I wouldn't re-use the old rod bolts.  maybe get a NEW tap and die and run the threads on the bolts and rods... look into newer rod style that fits the new bolts?.?.. yea, I know,, more $$$ to spend,, but I really hate to see you open a window in the block after ya done all this work..
or maybe contact ARP and see if they have a solution....
Edited by Michael V (NM) - 52 minutes ago at 11:09am
