7010 cyl head
Sam T-Ga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Topic: 7010 cyl head
    Posted: 27 Oct 2016 at 5:43pm
Anyone have a good head for sale? Getting valve job on mine and machine shop calls and said my head is cracked. Head from 185 0r 190 will work
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 6:16pm
Where is it cracked?
Still in use:
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 7:00pm
I would try to find an earlier head without the copper sleeves. I put one on my 7000 after the head came up with cracks around the injector bores and the valves. The older heads have more meat.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 7:31pm
Machine shop said it was cracked at a valve seat. across head to seat, under seat and into air passage under valve. Hurst I have a 185 head on my 7000 also.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 9:48pm
Will need to change nut on bottom of injectors.    MACK
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2016 at 8:53am
Nut and the nozzle as well.
