7010 cyl head |
Sam T-Ga
Joined: 13 Sep 2009 Location: Monticello, Ga. Points: 392 |
Topic: 7010 cyl headPosted: 27 Oct 2016 at 5:43pm |
Anyone have a good head for sale? Getting valve job on mine and machine shop calls and said my head is cracked. Head from 185 0r 190 will work
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 27 Oct 2016 at 6:16pm |
Where is it cracked?
Still in use:
Hurst
Joined: 11 Sep 2009 Location: Midway, Ky Points: 1219 |
Posted: 27 Oct 2016 at 7:00pm |
I would try to find an earlier head without the copper sleeves. I put one on my 7000 after the head came up with cracks around the injector bores and the valves. The older heads have more meat.
Hurst |
1979 Allis Chalmers 7000
5800 Hours |
Sam T-Ga
Posted: 27 Oct 2016 at 7:31pm |
Machine shop said it was cracked at a valve seat. across head to seat, under seat and into air passage under valve. Hurst I have a 185 head on my 7000 also.
MACK
Posted: 27 Oct 2016 at 9:48pm |
Will need to change nut on bottom of injectors. MACK
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5149 |
Posted: 28 Oct 2016 at 8:53am |
Nut and the nozzle as well.
