7010 changing outer tie rod. Rh side
bleeds orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Topic: 7010 changing outer tie rod. Rh side
    Posted: 01 Aug 2019 at 9:19pm
Cant seem to get old tie rod out, this is the 21" long one. Right now I have one end chained to a dozer and other end chained to a truck heating it to cherry red and it won't budge. I thought about cutting two relief cuts in the caseing that the tie rod slides into to help break lose. Any help much appreciated.
Thanks cory.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 9:32pm
Remove whole thing and beat on sides while laying flat on hard surface. Work all around and full length. If you get carried away, your pounding will stretch outer tube to larger than you may want.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2019 at 8:36am
Lots of PD Blaster, patience and some heat. You might try twisting it using a couple of pipe wrenches or a pipe vise.
Dave974 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave974 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2019 at 10:42am
+1 for Blaster and twisting
Another thing to try might be standing the whole assembly on end and soaking it with PB Blaster or whatever you're using.  That way, it'll run down into the gap between the tie rod end and the outer pipe.  Let it soak, then repeat.
After several rounds of soaking, twisting in opposite directions with a couple of large pipe wrenches has worked for me in the past
When reassembling, some anti-seize should prevent it from freezing up again.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2019 at 10:47am
I wanted to adjust the stance of the front tires on mine.......I ended up giving up on one side.  I had the whole thing cherry red, submersed it while hot in a barrel of oil, let it sit for and hour.  Repeated 3 times.  Beat on it with an air hammer.  Never budged at all.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2019 at 12:22pm
Have you swore at it yet? That's what finally got it loose for me.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2019 at 2:13pm
Yes swearing at things seems to alleviate some of the frustration. Just got done swearing in the plumbing parts for the 1930's 1&1/4" claw tub drain cobbled into a 1914 farmhouse that I live in. From the tub into the wall, all the twisty turning parts were a pain to find. Got her done all in brass. The lead piping from the main drain stack up into the floor and inside walls ? for the tub and sink is another battle another day.  $*#T  D*^n  H#!!Exclamation
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2019 at 6:06pm
Heating it is the big gun. But it didn't work. Darn, heat and torquing always works.
Is there any chance someone welded it or pinned it, now mechanically locked?
Before you go too medieval on it, check for availability of replacements...
In addition to all you have tried, I might soak it in Evapo-Rust for a week.
That could dissolve the rust away, if it can get in there. Has to be clean of oils.
Is this a "normal design" tie rod- hollow tube necked down at the end, this shorter area is the only contact area?
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2019 at 7:39pm
Never use heat on tie rod bar. You will ruin threads and the whole thing. Take complete assembly off. Lay on big anvil or nice flat surface. Use big hammer and work it all around good. Helps to have two people so one can hold it and rotate constantly. Once it starts to turn then you can add some spray lube. It will come apart!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2019 at 8:07pm
Take a 3 inch cutting disc on a grinder and make a lengthwise slice on the underside of the large tube. Cut it clear thru until you hit the tie rod and probably a foot or more in from the tubes end. Disconnect the tie rod end from the steering arm and place it on a safety stand. Get a 4 ft long pipe wrench and begin to twist it one way (pushing down on the pipe wrench) while adding penetrating oil. All the heating you've done (cherry red ?) has made it tighter than it was before. When you get done, you can weld the slice back together if you like, but tight bolts seem to hold it just fine.
