7010 blinker problems
bleeds orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Topic: 7010 blinker problems
    Posted: 11 Apr 2021 at 9:01pm
The 4 way hazards work fine on tractor , but when you turn the knob to signal turning left the right side front hazard flashes as well.
Could the switch for left and right hand turn signal be bad?
Thanks cory
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2021 at 6:53am
If the problem is new on the tractor you've had for a while then possibly. I don't pretend to understand the switch circuit. But it reminds me of a similar problem I had when I worked at CEI building feed trucks. When positioning taillights in their new location, if the ground wasn't right it would do that same thing HTH
