7000 weights on 210
BiG210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BiG210 Quote  Post ReplyReply Direct Link To This Post Topic: 7000 weights on 210
    Posted: 09 Feb 2010 at 6:04am
Will 7000 front weights work on 210
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2010 at 7:02am
Work?? maybe....there are two 7000 series weights....62 pounders and 90 pounders. If they hang on the bracket, they'll probably work, but they won't look correct. All 6000 and 7000 series brackets are tilted forward so the bottom of the weight is sqaure to the ground. Your bracket isn't tilted, it's square to the ground.
dpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2010 at 8:45am
we had our 210 with factory suit case weight bracket with 7060 thicker weights on it. I know they had to cut a piece out so the weights would hang on the bracket. Looked all right but did not look like factory ones. Ended up finding some factory weights for it and welding back in the square chunk they cute out.
Dale Hardtke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Hardtke Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2010 at 10:28am
Have a Allis Chalmers 210 front weight bracket with the cutout to accept 7000 series Wts. for sale or trade.  S.E. Wi. (262) 719 3552
Mark D. View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark D. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 3:39am
What series of tractor came with the rectanglar looking 65 lb weight with the same kind of AC logo and hanging mechanism??  We have a set of 10 and would like to advertise for some more.
Miss Behavin - D21 Super Farm
Xcessive Tinkering - 190 XT Hot Farm Puller
Watch on YouTube - http://www.youtube.com/watch?v=J2TX1Af7aoA
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 5:56am
Mark you may be talking about the 200 series weights. I can't think of another tractor they were used on.
Leon B MO
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 6:30am
65 pounders were for 200-210-220's.....200's also had 75 pounders that came in a set of six that hung from a different bracket(same as a 185).
