7000 vs 8000
GWS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GWS Quote  Post ReplyReply Direct Link To This Post Topic: 7000 vs 8000
    Posted: 05 Nov 2022 at 8:34am
I loved my 7030, but it did have one little annoying problem. When I was trying to turn in a tight space at low rpms (backing something carefully into a shed), it was difficult to steer. I'd have to push the clutch in and fight the wheel, or bump up the rpms. I know a lot of older tractors do this.
Was this corrected in the 8000 series?
Thanks, George
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2022 at 8:46am
That part is same between them...I'd say your hyd system was not up to spec.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2022 at 1:09pm
sounds like one of several possibilities, worn pump, low fluid, plugged filter, contaminated fluid, sticky valve
