7000 valves
Glen S.C. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glen S.C. Quote  Post ReplyReply Direct Link To This Post Topic: 7000 valves
    Posted: 24 Apr 2024 at 9:33pm
Does the 301s have a problem with the valves breaking the lips on the edge off?  When I bought this tractor 2 cylinders had broken valves. Rebuilt the engine , new sleeves pistons , had the head done , new valves in those holes. Around 150 hrs had a valve go bad. Shop put the intake and exhaust in the wrong holes, had that fixed. Saturday night started skipping . Pulled head today #5 intake half of the lip gone #4 intake cracked . Not sure the hrs since last repair. Going to have all new valves put in this time. Tiered of doing this.          THanks for any input.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2024 at 9:38pm
No problems.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2024 at 5:40am
Are your injectors bad? Bad injectors can cause combustion chamber problems.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2024 at 9:02am
Our 7000 lost one once. I don’t remember it doing the damage loosing one on the 8050 did. At one point it was worked fairly hard so somewhat understandable.
Edited by victoryallis - 25 Apr 2024 at 9:03am
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2024 at 11:49am
as mentioned above, injectors faulty or installed wrong if Ambac or Bosch injectors, or inj pump timing can be off a long way. It's usually a poor state of tune that causes failures like this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glen S.C. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2024 at 7:14pm
Thanks for the info . Will check all of that. Doesn't smoke. Did have some turbo trouble a while back but put a new one on .
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2024 at 7:28pm
They're not all impervious.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glen S.C. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2024 at 7:48pm
That's pretty bad
