7000 series weights |
7060
Joined: 16 Sep 2009 Location: Missouri Points: 1155 |
Topic: 7000 series weightsPosted: 17 Mar 2010 at 5:23pm |
Ive got some front weights I am going to put on the front of my 7060. The number on the side of them says 267881 and below that it says -03-WA 2. What size weights would these be, and how many of them go on there. I think I only have 13, but there may be a 14th hiding in the weeds. Thanks
Dans 7080
Posted: 17 Mar 2010 at 5:30pm |
Theres only two different front weights (atleast that ive ever seen) for the 7000 series. the width of the weight will tell you the weight and how many will fit. The inch and a quarter wide ones are 62lbs and 15 will fit on the small weight bracket 7000-7060. The wider weights about two and a quarter wide are 100lbs and 10 will fit on the smaller bracket. The 7080 has a wider bracket and 14 100 pounders will fit. |
cwhit
Joined: 12 Sep 2009 Location: Sigel IL Points: 1014 |
Posted: 17 Mar 2010 at 5:49pm |
we've got the 60 pounders on our 7045. And a mixture of 60 and 100 on the 7020. Can't see any differents in the looks until you get a closeup look..
7060
Posted: 17 Mar 2010 at 6:57pm |
These weights look to be about 1 1/2" wide. On Agco parts books it shows you can have 15, 14, or 21 weight brackets. I thought I remembered DrAllis saying there was a 90 something pound weight too, maybe im wrong. I thought they were going to be the smaller 62 lbs like you guys mentioned, but there 1 1/2" thick. Im not sure how the clamps line up but it looks like the brackets 24" wide. Thanks
Dans 7080
Posted: 17 Mar 2010 at 7:06pm |
Il measure tomorrow i was just kinda guestimating. I will also measure the weight brackets for you. I do know that the fat ones are 100 and the skinny are 62 ive weighed them. The clamps will only work with certain numbers of weights you might not be able to add just one more might have to add or remove 2 or 3 to get the clamps to work right.
nickia
Joined: 11 Sep 2009 Location: alden iowa Points: 793 |
Posted: 17 Mar 2010 at 7:18pm |
looking for a set of weights for our 7080 in centeral iowa along with a allis quick tach
Dans 7080
Posted: 18 Mar 2010 at 4:15pm |
I measured the weights today, the skinny ones are 1.5" wide, the fat ones are 2.25"wide. The small weight bracket is 24.625" wide and the large weight bracket is 34.375" wide. The 15 weight and the 10 weight bracket are the same bracket and the 14 and 21 are the same bracket. It just depends on the size of the weight as to how many will fit.
7060
Posted: 18 Mar 2010 at 7:38pm |
I guess I have the smaller weights with the small bracket then. I ended up putting 11 on it since I only have 13 and the next step up is 15. Thanks |
Lester
Posted: 18 Mar 2010 at 8:14pm |
My 1977 7060 has the wide bracket and has 14x100lbs weights on it.
