7000 series stadium lights?
rrhead(SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Topic: 7000 series stadium lights?
    Posted: 01 May 2011 at 8:35pm
Is there a source for stadium lights for my 7020? Are they available from Agco? Mine are rusting and 2 have fallen off this Spring. Thanks, rrhead(SD)
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 8:38pm
you can use about anything you want, as long as the switch/wiring/relays are heavy enough! i made a set with lights off an old combine for my 7080!
DOlson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DOlson Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 8:44pm
All of the stadium light parts were still available this winter when I checked.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 9:55pm
Does that include the chrome bars?
Hurst
1979 Allis Chalmers 7000
5800 Hours
hotwire View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotwire Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 11:25pm
if you have a salvage yard near you the lights of a new holland tr 70 or 75 have the same lights.they have a 3/8 inch mounting bolt and the same plug on the light and also the rubber around them.
