7000 rpm surges
Tony Elo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Elo Quote  Post ReplyReply Direct Link To This Post Topic: 7000 rpm surges
    Posted: 08 Oct 2011 at 3:13pm
I have a 7000 maroon belly,the rpm is going crazy at idle sometime.It revs up and down on its own,it even stalled itself once.I read a past post and somebody mentioned something about rubber O rings in the injector pump govenor,is this a costly job if I take the pump off myself?Thanks Tony
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 6:20pm
im not sure bout the o-rings but i kno our 301ci surges when the fuel filter needs changed maybe this will help ya.
      Shawn
190XT,D17and 7045
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 8:06pm
If your thinking governor flex ring, your DM doesn't use that setup. Odds are air is entering the fuel system at the pump inlet or hand primer.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 10:12pm
If it still has the small plastic line coming from top of tank to pump. replace it with one coming from bottom of tank to pump. May also need gov. linkage cleaned in pump. MACK
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 12:31am
same with my 7010, like xt said!
