7000 radiator cap psi
cmalcom20 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cmalcom20 Quote  Post ReplyReply Direct Link To This Post Topic: 7000 radiator cap psi
    Posted: 07 Jun 2025 at 3:32pm
Putting a new radiator in and figured I’d get a new cap to go with it. Currently has a 7psi cap on it, I thought they were 4psi systems? Does it make that much of a difference?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2025 at 7:53pm
12 psi from the factory.
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2025 at 6:48am
Pressure Caps make this much difference:
A 50/50 mix of water and antifreeze has a boiling point of around 223°F (106°C) at atmospheric pressure (0 PSI)However, this boiling point increases as the radiator cap pressure increases. For every 1 PSI of pressure, the boiling point increases by approximately 3°F.
This page was generated in 0.091 seconds.
