7000 pusher bolts |
Mrgoodwrench
Joined: 03 Apr 2011 Location: CHICORA PA Points: 2095 |
Topic: 7000 pusher boltsPosted: 23 Oct 2023 at 12:21pm |
i need a set of pusher bolts for a 7000. I figure with a d-19, 3-190's and 2-700's around i should just get a set to keep. does anyone have any experience with the ones being sold through some tractor parts places or on ebay? i can get them at sandy lake for $100 a bolt. the ones on ebay for example are $40 a bolt but look to be cut from regular bolts. others look to be fully machined from stock and are $170 a set. but I certainly don't want to but complete junk but considering I've never really had to use them I don't really want to spend $300 for them to sit in the toolbox. I might be interested in a used set if anyone is selling.
Model 70
Joined: 09 Jan 2021 Location: Minnesota Points: 151 |
Posted: 23 Oct 2023 at 12:28pm |
Just bought a set from A&W tractor, they worked great on my D19
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 649 |
Posted: 23 Oct 2023 at 2:07pm |
Just my 2 cents here
Id get a set from agco If those bolts arent the right temper and start galling in the wedge it could turn a simple job into a nihgtmare |
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
Mrgoodwrench
Posted: 23 Oct 2023 at 3:12pm |
That's not a bad two cents. I was kind of thinking that way after looking at the after market ones.
Alvin M
Posted: 23 Oct 2023 at 3:15pm |
AGCO Part # is 70235674 At 82.17 each plus shipping
Leon B MO
Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2200 |
Posted: 23 Oct 2023 at 5:00pm |
And to think Allis Chalmers gave a set away with each brand new tractor I've got a set from a 200 and an 8050 bought new in 74 and 85.
Leon B Mo |
sparky
Joined: 13 May 2011 Location: So. Indiana Points: 1793 |
Posted: 23 Oct 2023 at 5:24pm |
How many bolts make a set?
DougG
Thanks(1)
Posted: 23 Oct 2023 at 5:58pm |
3
sparky
Posted: 23 Oct 2023 at 6:37pm |
Okay thanks
LRWSPWI
Joined: 12 Aug 2012 Location: Sun Prairie Wi. Points: 194 |
Posted: 23 Oct 2023 at 6:43pm |
I built my own for my 200 out of the proper size grade 8 bolts. The wedges were really stuck in the wheel centers, but after a bunch of WD 40 (patience), and some tapping around the centers and putting more pressure on the push bolts every now and then they eventually broke loose.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8685 |
Posted: 23 Oct 2023 at 7:09pm |
Don't forget the "trick"....tire jacked off the floor,keyway on top,jackscrews torqued up and BFH applied to end of axle.
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1079 |
Posted: 23 Oct 2023 at 9:29pm |
Contact Lynn marshal. He had some for sale. Look back in the classifieds…he had a post there
KJCHRIS
Posted: 23 Oct 2023 at 11:29pm |
I got a set from an online auction a couple years ago. They were only 1/2 hour drive away.
Talked to the guy before bidding, he'd got them new @ AC Dlr to move in wheels going from 38" to 30" rows on his 190XT and a neighbor used them to do same thing.
only AC orange
Joined: 06 Dec 2014 Location: Eastern Indiana Points: 554 |
Posted: 24 Oct 2023 at 7:29am |
I've made a set out of grade 8, 3/4" bolts - machined end to fit in hub. Have used several times with '0" problems. Just used on D-19 last week.
