7000 ps end cap |
tnboss ![]() Bronze Level ![]() ![]() Joined: 31 Jan 2012 Location: iowa Points: 11 |
![]() ![]() ![]() ![]() ![]() Posted: 14 Dec 2020 at 9:51am |
Replacing the low range clutches in my 7000, Has wore grooves in the heavy end plate, can I polish the other side up and flip over afraid grooves will ruin new friction plates. Thanks for any help.
NEVER green ![]() Orange Level Access ![]() Joined: 28 Feb 2013 Location: MN. Points: 8607 |
Dont see why not, I did on my 7040.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21997 |
I think I would grind the damaged side to smooth. I don't think the front face was ever finished off, was it ??
Hurst ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Midway, Ky Points: 1218 |
Check for flatness too. Mine was warped when I rebuilt mine. If you’re working on a black belly that uses it as an inching clutch, they take a beating. In all honesty, if I was doing it again and didn’t find a good low hour used clutch pack, I would get a quote from a local machine shop to make one. I don’t remember there being much complicated about them.
Hurst |
1979 Allis Chalmers 7000
5800 Hours |
There may be room enough to make it 1/8" thicker, which would help with warpage over time. Machine it down at the O.D. to still use the same bolts, but thicker where the heat actually is.
