7000 hydraulic pump
Andrew(southernIL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Topic: 7000 hydraulic pump
    Posted: 28 Dec 2011 at 5:04pm
Been having to bleed the pump everytime we start the tractor (maroon belly). Doesn't take much just crack open one line at the pump and wait a few seconds then tighten back up. Any ideas on possible cause.
If fishing is a sport your looking at an athlete
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2011 at 9:39pm
Front seal in pump needs replaced or hose clamps on suction hose needs tightened.  MACK
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2011 at 10:23pm
Also could be the doughnut gasket on the suction line at the sump.  But usually that will be a dripping leak there.  Someone on here once said they had a pin hole in the elbow suction hose at the pump.
Hurst
1979 Allis Chalmers 7000
5800 Hours
