7000 hydraulic pump kit |
dp7000
Joined: 26 Sep 2021 Location: Winchester Kent Points: 141 |
Topic: 7000 hydraulic pump kitPosted: 17 Jan 2024 at 9:45pm |
Hello Big Orange experts. Where’s the best place to get a kit for a black belly 7000 hydraulic pump? I searched archives and didn’t find any recommendations. Thanks much. dp
Posted: 17 Jan 2024 at 10:18pm |
I've bought two kits from A & I and was happy with the parts.
dp7000
Posted: 17 Jan 2024 at 10:31pm |
Thanks Doc, exactly what I needed to know. I value your experience and opinions.
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3539 |
Posted: 18 Jan 2024 at 8:24am |
We use the A&I kit but if we need individual parts the AGCO old White/Oliver PN#s are still available. 20-7300762 20-7300763 20-7300764 are the outer ring and eyeglass seal both blue and soft black. 24d001 is AI the kit with plates and 70255947 is the AGCO seal kit w/o the wear plates.
Hurst
Joined: 11 Sep 2009 Location: Midway, Ky Points: 1219 |
Posted: 18 Jan 2024 at 11:17am |
Is the 24d001 the one for the 2 section pumps the 7000's use? Just verifying because the online retails I have found don't list the 7000 in the application list, but I thought the pump was more or less the same as the 200 pump.
Hurst
1979 Allis Chalmers 7000
5800 Hours |
Posted: 18 Jan 2024 at 11:59am |
Kit for 180/185 will work extra parts leftover.
dp7000
Posted: 18 Jan 2024 at 2:46pm |
Interesting, I think the front seal is out on mine. Was using tractor to unroll hay, backed up to a roll and lift arms wouldn’t raise. Heard a pop but don’t know if it’s related. Was very cold. Steering worked as well as power shift. As I returned to the barn to change tractors lift very slowly came up. I looked in the hydraulic filler tube and saw oil moving with air bubbles. Do you think front seal is all that’s needed?
Posted: 18 Jan 2024 at 5:36pm |
My experience with the front seal is the pump loses it's prime. If it has blown out I'd expect engine oil level to maybe raise ??
dp7000
Posted: 18 Jan 2024 at 6:38pm |
Engine oil unchanged. I think it’s sucking air. I read on another post there’s an elbow underneath? I haven’t looked into that yet. It’s been too cold. I don’t have a heated shop.
Hurst
Posted: 26 Jan 2024 at 8:44am |
If sucking air, check the elbow and also the doughnut gaskets on the suction line at the pan.
Hurst
5800 Hours |
