7000 fuel pump leak
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Topic: 7000 fuel pump leak
    Posted: 22 May 2017 at 7:35pm
I've noticed a weep getting worse on the fuel shut off shaft. It looks like I just need to order some seals and washers. But is it ever that easy.  Tim
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 7:42pm
The shaft seals are o rings. Replacing them involves removing the shafts from the pump which normally involves removing the pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 8:09pm
That's about what I figured. Thanks Joe
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 8:37pm
those orings can be replaced without removing the pump, at least the shut off side. Any pump shop will have the oring.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 8:38pm
Has the pump been off recently?
The Roosa Master pumps I have removed or installed had two seals (not O rings) on the shaft. If you aren't careful when installing the pump, the seals can get twisted. When that happens you get diesel fuel in the engine oil (crankcase).
It may be possible to have an exterior leak, also, but I have never had that experience.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 8:56pm
Those are called umbrella seals on the shaft and there's a special tool to put them on correctly, that's all internal on the pump drive shaft and inside the pump tube, if this would cause the O rings he's talking about to leak the oil pan would be over flowing with diesel fuel,
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 9:00pm
If you remove the screw and lever out of end of throttle shaft, shaft should come out. Have only found one out of a bunch that would not come out.    MACK
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 10:13pm
You're talking about a couple of different problems here.  DB pumps (180-185-190-200) use those umbrella seals on the DRIVE shaft. DM style pumps,( all of the 7000 series) don't. Yes, the umbrella seals can be tricky.  The seals that Tim is talking about on the shut off and throttle shafts are just O-rings that can be changed fairly easily. The top on the pump needs to come off,then a J clip needs to be removed.  The fuel shut off O-ring is the easiest, but the throttle shaft O-ring can also be replaced by doing what Mack says. I made a stubby ,bent allen wrench to do that job. They are common O-rings from the diesel pump shop. I also replace the top cover gasket. Hopefully you don't break off one of the three bolts that hold the cover on. Pay close attention as to the parts that have to come out so they go back correctly. Extra clean is also good.
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 6:57am
Google You Tube Roosa Master and see if that helps.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 7:48am
I am far from a professional but a similar Roosa on one of our L2s did that a few years ago. AGCO had the o-ring for a reasonable enough price and I was able to put it in without removing the pump. I think I took the screws out to remove the top of the pump on the combine so I was able to see a little better but it wasn't a big deal. Good luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 6:36pm
Thanks everyone for all the advice. I'm going to PM Ed for parts.  Tim
This page was generated in 0.091 seconds.
