7000 fuel leak |
cmalcom20
Topic: 7000 fuel leakPosted: 02 Mar 2026 at 9:08am |
Have a maroon belly 7000. I have what looks like a fuel leak around an injector? Is it just replace the rubber gasket around it? Tried to upload pics but they’re to big
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8936 |
Posted: 02 Mar 2026 at 9:12am |
99% of the time it is the valve cover gasket leaking into injector hole and back out. It is not the injector leaking. Don't be decieved...
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7624 |
Posted: 02 Mar 2026 at 3:16pm |
x2
Hurst
Joined: 11 Sep 2009 Location: Midway, Ky Points: 1220 |
Posted: 20 hours 17 minutes ago at 1:48pm |
They have copper sleeves around the injectors that are swedged into the head. If you cause one to come loose removing an injector, you have to remove the head to replace the sleeve. Just saying that to say I would not go right into pulling an injector without ruling out everything else.
Hurst
1979 Allis Chalmers 7000
5800 Hours |
AllisFreak MN
Joined: 07 Dec 2009 Location: Minnesota Points: 1613 |
Posted: 16 hours 24 minutes ago at 5:41pm |
X3 on the valve cover gasket.
