7000 fuel economy? |
Post Reply |
bakwoodsfarm
Orange Level Joined: 02 Sep 2010 Location: Woodleaf,NC Points: 511 |
Posted: 15 Dec 2018 at 2:22pm |
Just wondering about the fuel economy on the 7000 tractor, I have a decent lead on a black belly. I use the 7045 P/S on the 15' bushhog and the fuel economy is killing me. It uses twice the fuel that the 7050 P/D uses doing the same job and the 7050 has been turned up a "little". Not mowing anything heavy, just corn stalks and around the edges of fields. Thanks, Brad
Orange Level Access Joined: 12 Sep 2009 Points: 19498 |
Are you actually using a gallon counter at your fuel barrel or just going by the gauge on the instrument panel?? Looking at Nebraska Testing for both the 7045 PS and 7050 PD doesn't make me think there is much difference if everything is right on each tractor. Each tractor at 100% load uses 9.9 GPH (146 HP) and 9.8 GPH (156 HP). Each tractor at a lesser load uses 7.9 GPH (100 HP) and 7.5 GPH (105 HP). Each tractor at even less of a load uses 6.5 GPH (68 HP) and 6.1 (71 HP). The 7050 is slightly more efficient due to the intercooler. Being "turned up" slightly has no bearing on this. So, your 7045 has something wrong with it or you're not measuring gallons or there's a fuel leak onto the ground below when operating. The model 7000 at 106 HP uses 6.8 GPH which is 100% full load.
bakwoodsfarm
actual gallons of fuel in a days time, both hold about the same gallons(neither have the aux tank). Pulling a JD 750 15' drill, I can go 2 days (about 80 acres) with the 7050, the 7045 will go 1 day and have to fill it up again, both running close to the same speed. It just seems like the P/S takes alot of power out of the eng. Might have something wrong, but sure does run good. Only difference between the 2 is the 7050 has duals.
bakwoodsfarm
and no leaks(i make sure of that). Never really thought about the L3, it can cut 40acres of beans (50 bpa) on a tank. But that is 85 gallons.
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7943 |
Its the Powershift verses the Powerdirector, just like an automatic tranny in a car verses the standard clutch car set up ,, autos all use more fuel and a AC Powershift is basically an auto
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4385 |
When we were farming, we had a 180, 185 and a 7000. There was not a noticeable difference in fuel consumption between the three.
allisbred
Orange Level Access Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |
Not sure how heavy your corns stalks are, but 200 pba+ corn around here would work the snot out of a 301 with a 15’ mower with any ground speed. Just a thought
The drawbar performance tests are as follows: 7045 Power Director in 4th gear S L made 123 HP @ 5.2 MPH and burned 10.1 GPH of fuel. The 7045 Power Shift in 1st gear hi range made 123 HP @ 4.9 MPH and burned 9.8 GPH of fuel. In actuality, the AC Power Shift was VERY efficient in gears 1 and 2. It was equal to most gear transmissions in 3 and 4. When in 5th and 6th gear it wasn't quite as efficient as the standard transmission. Anytime I can do my work in 1st or 2nd gear high range, I do. Not always possible, but when it is take advantage of it. There is no torque converter on an AC Power shift like a car. Your main fuel tank is 51 gallons. How many gallons per day for each one ?? I don't think the 7045 is using twice the fuel of the 7050.
Adam Stratton
Orange Level Access Joined: 11 Sep 2009 Location: SW MO Points: 1363 |
Do they have the same injectors and have they been serviced recently? I have a black belly 7000 that I really like to bush hog with. I pull a 20'with it and get along fine unless its really heavy stuff.
bakwoodsfarm
I bought the 7045 about a year ago, has 4755 hrs on a working tach. Doesn't appear the engine has ever been touched. The 7050 I've had for 5 years and had in-frame done about 2 years ago. Both have the same straight pipe cut from the same piece. Don't have a gallon meter on my service truck, but the 100 gallon tank in it fills the 7045 twice in 2 days and I have to go get more the second day to fill the 7050. Maybe I need to have the pump and injectors rebuilt, but she does run good and smooth with plenty of power. And you don't really need 140hp on a 15' bushhog.
bigal121892
Orange Level Joined: 05 Jan 2010 Location: Nebraska Points: 738 |
By chance does the 7050 have the aux tank, and the 7045 does not? The 7050 is a little better on fuel, but not by that much, there is something wrong with the 7045, IMHO.
rw
Silver Level Joined: 28 Oct 2009 Location: United States Points: 377 |
I have seen fuel gauges that seemed to go down faster the closer they got to empty or vice versa. Weight of each one might need to be considered. Another thing that possibly could account for the difference might be some error on the tach reading. Loose belts or worn pullies to the alternator could have them running different true crankshaft rpms. I have seen my tach change 300 rpms when I turn the A/C fan off or on. That said my 190Xt seems to barely use fuel compared to the 7045 or 7060. I do not have a meter on the pump. If you are not measuring the gallons and doing identical work at identical rpms you are really just judging off perception.
allisrutledge
Orange Level Joined: 30 Mar 2010 Location: SurgoinsvilleTN Points: 1352 |
How did the sale go today?
bill2260
Silver Level Joined: 30 Mar 2010 Points: 215 |
New holland 648 round baler using 185 burned 2 gallons per hour. Upgraded to 8030 power shift same baler almost not quite 4 gallons per hour
fourthgeneration
Bronze Level Joined: 03 Jan 2017 Location: ohio Points: 170 |
Are you sure your pump and injectors in optimum working order. We have an 8070 and if I’m not tilling it’s not bad on fuel. We also have an 7020. If I had any input when dad bought the 7020 it would have been a 7045 but I was only 12 then.
bakwoodsfarm
The 7050 had a leak in the aux tank, so I removed it. Scott, the sale is online and ends Monday at 1200. Talking weight, the 7045 does have quite a bit more weight, inside and outside wheel weights and 20.8x38 loaded rears. The 7050 has no wheel weights and 18.4x38 duals with inside loaded. That might be the difference.
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4766 |
how does the smoke from each compare? I'm with Dr on this, those 2 tractors should be similar in fuel use doing the same job. The duals may help the 7050 move over more acres on same fuel compared to the singles on the 45. But if I remember right, they were not always doing hard drawbar pulling. Any tractor with a 301 will be using less fuel than a 426 doing the 100 hp type of jobs.
bakwoodsfarm
no smoke, just the usual slight dark haze while pulling my average loads on each.
rw
A turbo boost gauge can be a good way to measure the percent of full power you are putting out. It probably would not mean much to compare one tractor to the other but you might find that the extra weight on the 7045 means it is working pretty hard just moving itself. The bigger diameter tires for the 20.8 tires loaded will be heavy.
wfmurray
Orange Level Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
Fluid in tires will hold back if you are running any speed..Dad had a cub when i was growing up and it would pull a trailor up this hill in high without fluid. With fluid it would not. Fluid swings to back of tire with speed and holds back.
WD45Diesel57
Orange Level Joined: 20 Jul 2010 Location: Varna, Ont. Can Points: 646 |
when I had my 7020, I used it on a 15' disc bine and it was a good load on the engine, and with my calculations at the fuel tank filling up start and finish it was using 3.9 imperial gallon an hour (4.68 us gallon), now mind you that is the 301 649I in it. I was impressed with its fuel economy for what it could do!
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
AC7060IL
Orange Level Joined: 19 Aug 2012 Location: central IL Points: 3197 |
About your 7045's weight: Typical Inside rear weights weigh 400lbs each. Typical Outer rear weights weigh 300lbs each. 20.8-38 fluid could weigh 1500lbs each tire. So what number of weights does it have? 7050's 18.4-38s fluid could weight 1200 lbs each tire. So it's probably carrying 2400lbs max in its rear tires. |
Lonn
Orange Level Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29773 |
I can tell a difference in my 7050 just with the added 1000# weight on the front end. I'm guessing the weight of the 7045 is one issue and no duals is another that makes it use more fuel. Especially if it's in soft ground and the 7045 is always climbing out of it's own wheel tracks. When Dad rented out his farm for a few years the neighbors who then ran it said that they used more fuel when on Dad's farm compared to their farm. They figured because the ground was softer, softer not wet, than their land and their big heavy tractors were always climbing up out of their own tracks. It was very noticeable to them. Edited by Lonn - 18 Dec 2018 at 8:05am |
Wink I am a Russian Bot |
bakwoodsfarm
Thanks guys, I'm thinking weight is the issue(pretty much), I counted the weights on the 7045, it has 2 on each inside and 3 on each outside, full set on front and fluid in rears. So it has about 6400lb on the rear and 1000 up front. No wonder it cant get out of its own way. The 7050 only has fluid in the inside tires.
rw
Sounds like you better buy the 7000, make it light as possible, use it some of the time to help your average fuel usage.
AC7060IL
Yes, your 7045 needs a weight diet? The fluid weight in its 20.8-38s should easily suffice most traction requirements. Because of its current weight(22,000#), it's engine & drivetrain is being severely punished just to move. Since it's rear end is nailed to the ground, it's not allowed the required relaxation (wheel slip) during field operations. In Norm Swinford's book on page 170, it list a 7045 PS unballast @ 14,600# & ballasted @ 18,990#. The weight difference is 4390#, minus diesel weight @ 350# = 4050#. So 1000# front weights plus 3000# rear fluid, should be maximum. If you decide to reduce its weight, please follow-up later to let us know about its fuel usage then. |
skateboarder68
Silver Level Joined: 29 Jan 2011 Location: Keota, IA Points: 368 |
+1 It has loaded 20.8x38 tires AND 5 sets of rear weights?? I would leave the fluid in and the front weights and lose everything else. How is the air filter? I think your main problem is way too much weight
Orange & Silver still earnin their keep on the farm: R62, Series IV D17 nf, 185, 6080, 6080 fwa, 220, 1968 D21, 7045, DT240.
Lonn
It's like the supposedly famed Deere 6030. No ballast it weighed at least 18,000# and it was a dog. Everyone back in the day knew it was a dog..... until the owners started cranking the engines to 250 or more and then kaboom! goes the engine not to mention increased drive train problems. Worse yet was the 5020 all because they were way too heavy.
Post Reply | |
