7000 3rd gear change
Bob C IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Topic: 7000 3rd gear change
    Posted: 26 Jun 2013 at 8:23pm
who can make a set of gears to put in trans to speed up tractor above 4 Low. like in place of 3rd. need more than one gear....
YT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote YT Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2013 at 9:03pm
Try Bernie Platz in Sigel,Il.
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2013 at 10:49pm
If you want a gear close to 4th you will have to change both the input shaft and gears in conjunction with the third gear pair most likely.
7000 gears have a different shift collar (more dogs to grind into) than a 180, 185, 190, 200 trans mission. So don't let anyone sell you 190 gears and say they are a direct fit - they aren't. I think the countershaft splines are different also.
Edited by O.P.S. Heads - 26 Jun 2013 at 10:51pm
