700 series deck
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Topic: 700 series deck
    Posted: 04 Oct 2023 at 8:00am
Are the bearings on the deck special or can I get new ones at like a parts store
Leadoff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leadoff Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2023 at 8:20pm
DaveWisc
I purchased new bearings from the local Simplicity Dealer last year when rebuilding my 48" 700 Series Deck.  They work well, and I don't believe they were anything special.  The Dealer had them in stock.
Water/wet grass and dust/dirt is probably the number one operating concern for these bearings.
Good luck
1963 D17D Series III. 1965 D15 Series II. 1965 D17 Series IV. 1975 185. 1978 716H. 1979 716H. 1965 780 Harvester/1R&DC. 1957 Model 73 SC 4 Furrow Plow
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2023 at 8:59pm
I got more problem with the deck I need the center hub on the mower deck. Hope someone has a good one it is a Simplicity deck which is different than Allis Chalmers
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2023 at 9:32pm
Does this deck have the heavier cast center pulley.
Does it have one or two bolts holding blade on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2023 at 6:41am
It has two bolts that hold blade on . The top has a big self locking nut .It is a Simplicity deck I gave two Allis decks but are different and will not work
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2023 at 6:56am
Look like this. This is bottom side.
We have some of those decks too. I hope you don’t need the arbor shaft for center.
If you’re needing the top hub that pulley bolts to. We have had problems with those too. And can help you.
Edited by Mikez - 05 Oct 2023 at 7:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2023 at 7:43am
That is what i have and the belt pully bolts on that piece.My shaft is bad too but can get that fixed. How much for that piece  i  live in Southwestern Wisc. Thanks Dave
This page was generated in 0.186 seconds.
