70 series planter setup
klocke.kyle@yahoo.co View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klocke.kyle@yahoo.co Quote  Post ReplyReply Direct Link To This Post Topic: 70 series planter setup
    Posted: 30 Mar 2024 at 8:26am
If anyone has a 70 series manual. I’d appreciate some help. My planter right now is set up on 30” rows with 24 cell sunflower plates. It has a 18 tooth drive socket and a 10 tooth driven socket. Would anyone happen to know the seed spacing I would have with this setup?
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2024 at 8:52am
We lost all our manuals -but
Even though it is flat chain 74 series the charts are the same.  You could do the math - a 10/14 = 8" spacing.  A better method is to measure the OD of your drive tire - Roll it one revoution exactly - and count the seeds and divide into the circumfrence.  Kee in mind some sunflower seed plates require a filler plate as sunflower seed are half the depth of a corn kernal.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2024 at 10:23pm
Old school method is drag it down the hard dirt driveway and then measure/count the seed drops.
Next best is measure the diameter of the ground wheel you have and then the teeth per gear involved. Ratio everything and there you go.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2024 at 3:58pm
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2024 at 11:00pm
Jvin248, you just brought back a memory for me of my dad and grandpa. I can hear my dad telling my grandpa it wouldn’t work. He said he couldn’t pull that planter in that hard ground. Grandpa said sure you can. I’ll even help push if I need to. Thanks for the memories.
