6x6 |
shameless dude
Topic: 6x6Posted: 07 Jan 2023 at 12:54am |
well...the 6x6 ATV i bought for the old lady.....ooooooops....I mean the loving wife, is sitting, won't run, has a Kohler V-twin OHC engine. runs on carb cleaner and starting fluid, flushed the fuel system and lines, new gas with a little bit of HEET in it, took the fuel pump hoses off (vacuum pump) and wasn't getting much out of it, order and replaced the fuel pump, still no change. sprayed lots of carb cleaner inside and outside the carb. am affraid to take the carb off, last time I messed with a little carb, a little spring zinged out and was never found...guess it was an important one! any ideas?
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55292 |
Posted: 07 Jan 2023 at 4:43am |
if you can find the ID tag on the motor, it would help tremendously!
Dave H
Joined: 11 Sep 2009 Location: Central IL Points: 3607 |
Posted: 07 Jan 2023 at 5:30am |
how about the fuel filter? |
Kansas99
Joined: 26 Feb 2015 Location: W Kansas Points: 4868 |
Posted: 07 Jan 2023 at 6:22am |
If there is a fuel shutoff the needle and seat are stuck shut. Had it happen on my generator and it didn't take long, it had sat for a little over a year without running. If memory serves me right it's on the side of the carb. Edited by Kansas99 - 07 Jan 2023 at 6:25am |
fixer1958
Posted: 07 Jan 2023 at 7:07am |
Fuel lines rotten in the tank maybe and sucking air.
Ethanol is good for that.
JW in MO
Joined: 16 Feb 2010 Location: South KC Area Points: 2696 |
Posted: 07 Jan 2023 at 7:47am |
My 720, the dip tube in the tank has a hole or crack in it, I have to make sure fuel is above it. I replaced a perfectly good fuel pump also. I just ran a hose from the pump inlet to a can of gas to prove my problem.
fjdrill
Silver Level Access
Posted: 07 Jan 2023 at 9:03am |
I'm with K99. electric fuel S/O, lower carb, flywheel side. They are kinda pricy.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25262 |
Posted: 07 Jan 2023 at 9:20am |
me too.... the 'frugal fix' is to unscrew the 'anti dieselling valve'(B&S term), rip off the rubber, then replace. Now get get flow 24/7 BUT the needle valve IS the shutoff. I've done 2, cut the gas line installed a B&S shutoff It might just need cleaning. easy to test, clean then hit with 12v and be 100% sure it MOVES...
Dave H
Posted: 07 Jan 2023 at 10:02am |
good idea, this will instantly tell if you have a fuel restriction. Clue to the shut off thingy, it has a wire or wires hooked to it. Have a new one on order for nine.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35690 |
Posted: 07 Jan 2023 at 11:05am |
My Thermalarc welder was that way, had to braze the pickup tube at rust thru line and change all 'rubber' fuel lines. V-twin Honda on it.
shameless dude
Posted: 11 Jan 2023 at 7:53am |
fuel filter replaced, the gas tank is a gravity flow out the bottom, the hoses are clear (open), replaced a few hoses, will check the needle thingy when I go back out there.
JohnColo
Joined: 03 Apr 2020 Location: Niwot, CO Points: 1263 |
Posted: 11 Jan 2023 at 11:53pm |
Sounds like it will be a fun toy once you get it running. Now be honest, did you REALLY buy it for the old lady, er loving wife or for yourself?
shameless dude
Posted: 12 Jan 2023 at 3:39pm |
gotta be for her John....I don't fit in it!! (to chubby)
