6v and 12v Questions |
MilesGray (CO/KS)
Topic: 6v and 12v QuestionsPosted: 10 Jul 2010 at 9:50am |
The person I bought my latest tractor from told me that the 6V tractors aren't worth using in the field! While I'm not believing this as I know my 6V tractor was used by the previous owner for plowing, etc. I have two with 12V, one with 6V and 2 original with just the magneto. I didn't ask him his reasons, honestly, I think I was too shocked to come to come up with a respectful comment...
I have used both the non-electric and the 12V in the past to mow, and the only difference I can see is that the 12V is easier to start! LOL!
What are your thoughts on this? Seems that the only thing that you would have to watch out for is if the tractor needed a Jumpstart?
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy! |
TedBuiskerN.IL.
Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
Posted: 10 Jul 2010 at 10:03am |
I prefer to leave the electrical systems original on my tractors. Use the correct cables and keep things clean and they give no trouble. If you have increased engine compression significantly you may want to go to an 8 volt battery. But six volts will start almost anything that came with six volts originally. Just be sure to use the large OO cables to carry the extra amperage needed for six volt and original works fine.
kip in cny
Joined: 29 Nov 2009 Location: Jordan NY Points: 538 |
Posted: 10 Jul 2010 at 10:04am |
6 volt system will work fine for feild work. Dont trust everything people tell you. Last week I loaded 2 farmall H parts tractors up for a buddy and the guy who owned them told us that farmers use maple syurp in the rear tires for weight becuse its cheap and dont freeze. It was funny but he ment it.
160 CA 920diesel 5020 HD-3
pumpkin man
Posted: 10 Jul 2010 at 10:18am |
He wodnt want to use maple syurp at to days prices $15-$16 a qt thats not cheep
JW in MO
Joined: 16 Feb 2010 Location: South KC Area Points: 2671 |
Posted: 10 Jul 2010 at 10:37am |
The biggest drawback to 6v that I've found is the price of the batteries.
Dave(inMA)
Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |
Posted: 10 Jul 2010 at 10:53am |
Here's another post on a similar topic:
My view is that 6v systems work fine IF you do the work to maintain them. Anyone who says that aren't good for "field work" needs some education. If one understands the choices and decides to go with 12v, so be it. But you owe it to yourself to make a decision for the right reasons.
WC, CA, D14, WD45
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12024 |
Posted: 10 Jul 2010 at 11:06am |
As others have mentioned, the 6V system works fine providing all components are in good shape and in good working order. Everyone I talk to on the phone at the shop during the day all say the same thing. "The engine doesn't turn over fast with 6V's". That's because it wasn't designed to. With all components in top shape, it'll spin over plenty fast. The only time I recommend a 12V conversion to a customer is if the customer has more accesssories on the Tractor such as extra work lamps, aux. power outlets, sprayers, etc where more power is needed for correct operation of these accessories. Stroked puller engines and higher compression built engines also fall in this category. In most cases on the early AC Tractors, the 6V Gennies outputs are only good to around 18-22 amps. When adding more power accessories, this starts to take the 6V system out of the realm of reliable power on board the Tractor as well as putting the Gennie and its components in the "overload" area, along with feeding a Distributor fed Ignition system (if so equipped) as well as keeping the battery reserve full. In overview, the 6V system relies on its grounds to operate correctly. Old and corroded cables, wiring, rusty 3 position switches, and or sulfating batteries, add to the "non-reliable" rumor of the 6V system. Worn out Starter motors are a big problem to the 6V system in the starting department and moving to an 8V Battery is what the result is instead of getting the starter rebuilt correctly. In the Battery cable dept. 1 gauge cables are the standard for 6V systems. Anything heavier is a plus, but not really necessary providing the rest of the system is in good working order... HTH
Steve@B&B |
Gerald J.
Posted: 10 Jul 2010 at 11:10am |
With a 6 volt system, maintenance of battery cable connections, mostly at the battery posts is a twice a year ritual. You can get by doing that for 12 volt systems every couple years, but a 6 volt system WILL let you down much sooner. Its probably more of a problem on a tractor that's not run much than in a car that's run every day, but when I was young my dad's cars were all 6 volt and cleaning the battery posts was something we did twice a year. We didn't have the post brush so we used a sturdy pocket knife and scraped until the post was shiny. What came off was hard. Same thing for the inside of the cable connector, we cut hard lead oxide or sulfate away until we got to soft shiny lead. Grease was a good protectant. Many modern plastic cased batteries leak fumes around the posts which is harder on keeping the connections clean. The red and green felts help some there. In the old days with hard rubber battery cases, the posts were actually cast in place leaving no gap around the posts, but the modern plastic cases won't stand that, so there's a gap.
Sturdy battery cables (not from the Wallyworld kiosk) are critical to good starting with 6 volts, as are clean connections at the cable connections to the chassis, and to the starter switch. While some AC run the grounded battery cable to the battery box, it would be better if it was run to a starter mounting bolt. Gerald J. |
mlpankey
Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
Posted: 10 Jul 2010 at 1:44pm |
anytime you increase the voltage the cranking amps required will be lower.
Brian Jasper co. Ia
Posted: 10 Jul 2010 at 1:49pm |
I agree 100% with Steve and Gerald. 6V doesn't have much "room for error". I did convert my CA and Oliver 60 to 12V to add a few brighter lights.
mlpankey
Posted: 10 Jul 2010 at 2:13pm |
Steve is the insulation on 2.4 kw wd starter windings thick enough to handle 24 volts?
Gerald J.
Posted: 10 Jul 2010 at 3:54pm |
If you increase the starting voltage on a series wound starter on DC the amps will increase as will the torque. Its NOT an AC motor where the amps are inversely proportional to the voltage. E.g. on low voltage the AC motor draws more amps because the frequency sets the shaft speed and the shaft speed sets the load. It takes watts input (volts times amps times power factor) to create shaft horsepower. With higher voltage (until you run into saturating the magnetic core on peaks) the current goes down to produce the same horsepower.
But that's not the case with the series wound (as in starters with awound field) starter motor. It starts out stalled and the current is limited by only the circuit resistance, being that of the battery, the cables, the starter switch, and the starter itself including the brushes. When you raise the voltage you raise the current and when you raise the current you raise the torque so any old starter cranks any engine faster with higher voltage. And when you've bore, stroked, and increased the compression ratio, the old starter may not crank it without increasing the voltage. The main benefit of 8 volts vs 6 volts is it allows a longer interval for cleaning battery posts. They can get cruddier before it won't crank the stock engine. 12 volts on some magneto engines can make for poor starting because they crank too fast for the impulse mechanism to function, but not fast enough for decent ignition. As Steve points out, worn out starters, especially bearings and brushes are a problem just because a 6 volt tractor is 50 years old or older. The winding insulation in a motor is usually tested at rated voltage Plus 500 volts so the insulation isn't different for 6 volt vs 12 or 28 volt. I have run a 6 volt generator as a 12 and 24 volt motor without damage. it makes a fine 24 volt motor. But the field is fully saturated and probably also runs on the hot side which is what will take the generator out. The starter motor with its series field will scream like a banshee at 24 volts if the bendix misses and probably throw the windings out of the slots. I did that to a 12 volt starter on my gas 4020 a few years ago when something in the starter circuit stuck and kept it in gear with the engine running. That rebuild too a new armature as well as solenoid, bearings, brushes, and bendix. The series motor is a constant torque motor, so its not damage by stalling while cranking, but if its left unloaded and its more than a couple HP, it will spin faster than the winding anchors can hold the armature windings in the slots, then it stops in about 1/8tb turn locking the armature in the field poles. Sometimes it can be rewound. Gerald J. |
Kcgrain
Joined: 24 Sep 2009 Location: Wisconsin Points: 795 |
Posted: 10 Jul 2010 at 7:13pm |
after reading the replys and than reading , I am not sure if I agree or disagree, I am not sure why a tractor for "field work" would be any diffeent than one that sits around and looks nice, the function is the same when you hit the starter it better start, from my expierence other than wanting to keep someting "original" which is ones own perogitive I switch them all to 12V, one is the cost, and 2 if for some reason you want to jump start the tractor or another machine they are all the same, and 3 from working for an old farmer that had a WD45 that would start like a charm for him and nobody else on 6v, which drove me crazy. Since switching his WD 45 to 12 which requires a coil, battery a resistor and a 12v gen or alt, the starter for 6v I have been told has heavier wiring than a 12 so nothing needs to be changed there, and from my stand point when you go to start the 45 now when you pull the ring it starts for everyone .....right now..... rather than the wait I think it will no well maybe style of a 6v specailly after the engine is hot and has full compression, and probably dirty cables etc.As far as the maple syrup, I am not sure where that guy is from, one is the cost , and 2 it freezes.
mlpankey
Posted: 10 Jul 2010 at 8:09pm |
ohms law was written on pure dc circuits . the answere is yes it will start on 24 volts the starter ran cooler on the 24 volts than it did dragging on the 12 volt 1050 cranking amp. Did the test today after posting the question.
Chalmersbob
Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Posted: 10 Jul 2010 at 9:48pm |
I buy my 6 volt batteries for $55.00, they are Deka and made in Pa.
Bob
Brian Jasper co. Ia
Posted: 10 Jul 2010 at 10:08pm |
ML, did the whole tractor try to roll over on it's side? I remember the Myth Busters trying to verify a myth on CD's shattering inside a fast CD drive. They ended up using a router to do it. When they couldn't get the CD's to explode with the router on 120V, they switched to 240V. Then they didn't last long, neither did the router motor.
mlpankey
Posted: 10 Jul 2010 at 10:14pm |
no it didnt turn over on its side or flip over the wheelie bars were down
bigfish_Oh
Joined: 13 Sep 2009 Location: West Liberty,Oh Points: 1226 |
Posted: 10 Jul 2010 at 11:40pm |
If 6 volts aren't worth using in the field, what did he think of magneto's ?
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe 1951 WD, factory p.s. 1960 D14 HnMk IV BkHoe 4 sale 2014 HD Tri Glide 2009 GMC CC SLT Dually |
MilesGray (CO/KS)
Posted: 11 Jul 2010 at 12:57am |
Jerry used to be a puller so he had changed most of his tractors to 12V, but I will have to ask him about magnetos... |
Miles Gray (CO/KS)
mlpankey
Posted: 11 Jul 2010 at 1:35pm |
