6g injector pump
hindu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hindu Quote  Post ReplyReply Direct Link To This Post Topic: 6g injector pump
    Posted: 07 Feb 2011 at 7:45am
My 6g went to running wide open no matter what position the throttle is in even disconnected running it by hand at the injector pump it runs wide open anyone have this happen? Any help would be appreciated.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2011 at 12:14pm
You should have a broken rod or spring in governor control
Post Options Post Options   Thanks (0) Thanks(0)   Quote hindu Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 5:50am
I took the injector pump off and took it apart there is a very small nipple on the end of a shaft below the  injector head that is broken/worn off would you happen to have a parts breakdown for this? Thanks for any help you could give. Thanks for the reply.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 2:34pm
 I just check and remove the small cover with 2 screws and  the shaft is in good condition with a spring and a nippe at the end and in the inside cover CV9018
                                         gemdozer@hotmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote hindu Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 8:37pm
Thanks. I just sent you an e-mail.
