655 crawler
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Topic: 655 crawler
    Posted: 09 Mar 2017 at 7:27pm
Had a call today from someone looking for steering clutch discs for a 655. Not available from dealer. Not listed at Minnpar.  Where can a person get some?
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2017 at 9:17pm
Try General Gear.
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2017 at 10:40pm
I order mine bi-metallic disc, and brake bands from them for my hd4 allis  dozer. call 208-342-8911 Boise, Idaho
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 5:39am
Yes, General Gear in Boise - believe 655 uses same as H3 and HD4 series.
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 7:38am
$23.99 on eBay
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 11:41am
Odd as my HD4 used a single disc like automotive clutch disc and a Auburn type pressure plate
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 11:57am
That is the first time I have heard of that Coke.  Someone must have invented / rigged a new system on yours. Did the system work good ?  Any above normal slipping ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 12:12pm
Coke:  Is your post in reference to the engine clutch or the steering clutch? Manual for the HD4 shows a torque converter flex plate set up for transmitting power to the shuttle clutch transmission.
Steer clutches and pressure plate set up in HD4 very similar to the H3 series crawlers if not the same.
This page was generated in 0.206 seconds.
