|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| 653 track tension |
| Post Reply   |
| Bsumudd   Bronze Level   Joined: 26 Jan 2020 Location: Indiana Points: 35 |  Post Options  Thanks(0)  Quote  Reply  Topic: 653 track tension Posted: 04 Nov 2021 at 9:24pm |
   Hey guys, So my right track tensioner has moved back about a QTR of an inch leading to a significant loss of track tension. I cleaned out the dirt around the zerk fitting and started pumping grease in there. The pressure was so great I couldn’t pump anymore. I thought it was the fitting and replaced it. Same thing happened. All the while the front roller is still stuck in the same place. Any ideas on what could be going on and how I may fix it? As always, thanks for the help! | |
| Bsumudd   Bronze Level   Joined: 26 Jan 2020 Location: Indiana Points: 35 |  Post Options  Thanks(0)  Quote  Reply  Posted: 02 Dec 2021 at 9:05pm |
   Hey guys still haven’t figured out the track tension, but was hoping maybe someone could confirm something I heard.   I was told to lift the tractor with the blade and a hydraulic Jack and then put it in gear before adding grease.  Has anyone else heard to try this, or do you guys have any other tricks for track adjustment?
| JohnColo   Orange Level     Joined: 03 Apr 2020 Location: Niwot, CO Points: 1263 |  Post Options  Thanks(0)  Quote  Reply  Posted: 02 Dec 2021 at 10:10pm |
   I'm wondering if the front idler wheel bracket is frozen up to the point it will not move forward. | |
| Bsumudd   Bronze Level   Joined: 26 Jan 2020 Location: Indiana Points: 35 |  Post Options  Thanks(0)  Quote  Reply  Posted: 08 Dec 2021 at 6:14pm |
   I thought about that.   I am going to try two ratchet straps attached  to the blade and see if I can pull it forward that way.    We will see | |
| Bsumudd   Bronze Level   Joined: 26 Jan 2020 Location: Indiana Points: 35 |  Post Options  Thanks(0)  Quote  Reply  Posted: 09 Dec 2021 at 5:41am |
| orangeman   Orange Level   Joined: 12 Sep 2009 Points: 1857 |  Post Options  Thanks(0)  Quote  Reply  Posted: 09 Dec 2021 at 7:44am |
   A few things to consider - heat the slide bracket and frame of the idler both sides, if the machine is outside and in a freezing conditions.  Check for and aft movement of the idler with a block of wood and pry bar.  If the idler moves it maybe time to remove the hydraulic track tensioner and  service it.  Also, use the pry bar to see if there is any lateral deflection in the idler on its cross shaft.  Have seen 650 series machine lock up, (jam) a track due to an excessively worn cross shaft.  Check the measurement from the edge of the idler to the inside of the rail on both sides and see if they are close to the same.  If not, then add idler cross shaft service to the list along with service of the hydraulic track tensioner.  Lets us know of your progess.... ~ Orangeman | |
| Bsumudd   Bronze Level   Joined: 26 Jan 2020 Location: Indiana Points: 35 |  Post Options  Thanks(0)  Quote  Reply  Posted: 09 Dec 2021 at 9:18am |
   It does sit outside, but when if first happened (a few months ago) it wasn’t freezing yet.   I think your probably right, I might have more worn out parts.    Ugh
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
