653 quik-tatch bracket
trailduster View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote trailduster Quote  Post ReplyReply Direct Link To This Post Topic: 653 quik-tatch bracket
    Posted: 15 Jan 2010 at 8:37pm
looking for any info or direction to find a quick attach rear plate for hooking up a 615 backhoe to my 653. also in need of a pedestal seat for it. any help is appreciated
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2010 at 8:59pm
Check with Ivan Sumerix equipment,Lacine MI. HTH Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote trailduster Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2010 at 9:13pm
thanks Tracy !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2010 at 9:18pm
Ivan has more and knows of more parts on those than anyone I know of.If Ivan can't help. Try Blount used parts,Hoboken,GA. HTH Tracy Martin
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2010 at 5:28am
Have a 615 hoe yet off my HD4, on the bracket , it was also used as a tool carrier and used to attach weights to back. Hook on lower side that hoe dropped into and on the top two pin boss drilled through plate for top of hoe. 2 sides were attached to each other with X brace between. Long rod went from bracket to loader frame and this had a threaded end so bracket could be tensioned to loader frame.
 Seat bracket is just a flat iron with a hinge on end that attached to hoe. flip up to run machine, flip down to use hoe as seat ends up over opperator station of machine.
 On my hoe I replaced the lower 2 pins with a solid rod running across the hoe instead of 2 pins. Just dropped hoe onto lower hook area of carrier, then used hoe to position itself to fit top pins.
Edited by Coke-in-MN - 16 Jan 2010 at 5:31am
Post Options Post Options   Thanks (0) Thanks(0)   Quote trailduster Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2010 at 4:08pm
thanks for the info guys.  Coke is the bracket you described available for purchase? do you have measurements for the bracket and placement of the seat or possibly a photo as this sounds like something i can easily fab. thanks for your help!
        scott
