653 issues
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Topic: 653 issues
    Posted: 02 Jan 2018 at 9:30am
After years of searching I found my grandfather's 653. She's in rough shape but that doesn't matter. Guy parked it because it lost drive and I have to talk to him some more but I remember something about fluid loss. What are common issues with loss of drive? This is an early 653 with the dry clutches like an HD4. Thanks for any help!
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 9:44am
Yes if the torque converter or the clutch pack is low or empty - the machine will not move . dipstick under the right floor board and is suppose to be checked warm with engine running - it might have mark for off position but not a true reading
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 9:50am
Thanks Coke. Not sure if you saw the pics over on Facebook but she's not sged well since he sold it back in the early 90's. First on my agenda is getting it running when moving, then chase from there.
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 8:57pm
Where on Facebook do we look?
Allis Express participant
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2018 at 7:50am
its on the Allis Chalmers Crawler tractors page
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2018 at 8:30am
That has to be a good feeling to get that back in the family. Congratulations on finding it! Darrel
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2018 at 10:45am
Congratulations on getting her back in the family. That must be a great feeling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2018 at 8:10am
It was unbelievable to find it especially just a few miles from home. Been on a hard hunt for his D15 series 1 diesel also but it seemed to have disappeared.
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2018 at 8:28am
I understand. One thing about heavy equipment, in many cases it does not move far from home due to shipping. The larger the piece of equipment the closer to home base it can be. The HD16 I have went through 4 owners during the span of 1961 to present. I found each owner and the original owner and have talked to them all on tractor history and past issues or repairs. Tractor wound up roughly 150 miles from point of origin when I found it. Was pretty cool digging into to it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2018 at 6:29pm
Stopped today and got the manuals from the previous owner and talked to Jim a bit. Reason it stopped moving is it started dumping trans fluid. Once I get it home I guess I'm hunting for a blown line or seal. Any prone spots for fluid loss?
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2018 at 7:25pm
If you got the manuals - then your on the right track to find the problem
ac-mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac-mike Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2018 at 7:34am
  My machine has the foot steer drive. It developed leaks in the lines just below the seat and above the differential. It would really help if you knew the location of the drip falling from machine. Tough machine for a big man to work on!!!!!
D-12III, 200D, 170G, HD-3, D19D 3pt, D17D High Crop, WD45G p/s, D15IID, D15IIG, D15G IND, 655, (3)WD45D p/s, 700, 816
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2018 at 12:13am
my hd4 had leaks on bottom of torque tube housing covers. tightened down and stopped them. also as mike said the lines from the shuttle shifter to the side going into the torque tube assembly get rotten and leak. check to se if atf fluid is in the rear differential compartment. hope not !
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2018 at 5:13pm
I'll definitely check these things it. He said it definitely was dropping fluid out the bottom
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2018 at 12:46pm
She's home! Was very easy getting loaded. Did some more talking with the previous owner and he never found exactly what the leak came from but said it appeared internal. Just ATF was leaking. Possibly the Torque converter?
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
This page was generated in 0.296 seconds.
