653 Final drive |
sparkchaser221
Joined: 19 Sep 2017 Location: Byron Georgia Points: 2 |
Topic: 653 Final drivePosted: 19 Sep 2017 at 9:13am |
Allis Chalmers 653. My right side final drive housing cracked and took out the pinon gear. Does anybody know where I can get a final drive housing or a carriage assembly? I am located in Georgia. I also am looking for a pinon gear.
650, 653, 655 |
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Posted: 19 Sep 2017 at 9:34am |
This is on ebay now, located Century, AL
Allis Chalmers 653 Bull Dozer ( 162673712298 ) |
Big Jim
Joined: 19 Sep 2017 Location: West Virginia Points: 24 |
Posted: 19 Sep 2017 at 9:38pm |
I have a case setting in my shop. I can probably help with ever thing you need.
JohnCO
Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Posted: 19 Sep 2017 at 9:47pm |
That one on Ebay looks pretty good if you have the parts to fix it.
I see someone paid $3,450 for that Ebay one. Nearly a grand more then I paid for one that runs! Edited by JohnCO - 29 Oct 2017 at 12:17am |
Allis Express participant |
pinball
Joined: 28 May 2014 Location: missouriu Points: 6458 |
Posted: 20 Sep 2017 at 6:37am |
Do a search on the internet. that's how I found mine fOR my H4 which I think is the same. Get your pocket book ready. Don't be alarmed when you find one cause there definetly proud of them,
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42264 |
Posted: 20 Sep 2017 at 8:37am |
Watch the outboard bearing casting machining for bearing - that area is a weak spot in case and many have been repaired satisfactorily - but lot of cases with damage are still out there - and for that gear - bring lots of money as it's expensive - just like axles and the drive gear. been there / done that .
Had both cases machined to accept a steel insert to hold the Timkin bearing cup for the axle . went through 4 axles on my machines before it got traded in .
363ford
Joined: 27 Oct 2017 Location: West Virginia Points: 1 |
Posted: 28 Oct 2017 at 7:06pm |
Big Jim I sent you a message
Coke-in-MN
Posted: 30 Oct 2017 at 3:50pm |
It can be repaired by a good machine shop that specializes on heavy repair - I had a truck machine shop that does large transmissions and rear truck axles do mine on the HD4 as well as reinforce the ones on my FD5
