653 dozer forsale
PJsomd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PJsomd Quote  Post ReplyReply Direct Link To This Post Topic: 653 dozer forsale
    Posted: 22 Mar 2014 at 8:02pm
Just Fyi I seen this on craigslist eastern shore of Maryland for anyone interested.Not mine http://easternshore.craigslist.org/grd/4363368573.html
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2014 at 8:17pm
Why are all the good ones so far away?
  says one track jumps... probably needs new p&B and sprocket... $4500 or bo.
 Heres a live link to it.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2014 at 9:54pm
I'd like to have that lil devil. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2014 at 10:04pm
Theres probably more that would like it too... LOL LOL
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2014 at 11:44pm
I'd love to have it too but over 2000 miles away.
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2014 at 12:43am
Seems those that would like to have it keep getting further and further away. LOL
Here's a pic of it just to temp and tease others...LOL
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2014 at 11:11pm
after having a HD4 loader, and running out of hands with all the levers it would be nice to have a pedal steer machine .
 Then moving from a HD5 to a FD5 with the power-shift make things easy . Almost no cat skinning knowledge needed , well except to run the blade .
 Would almost be like going from HD4 to the 653 if it has the decelerator also.
WayneB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WayneB Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2014 at 10:29am
Needs right FD Pinion/Bull gear and other assundry parts to install. From what is learn, about $1500 in parts.  Talked to the guy.  Its been advertized for a while.
Wayne
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2014 at 11:42am
That is one of the weak spots on these machines - with single reduction case and small bearings holding these components - I replaced one pinion , one bull gear and 3 axles on my HD4 , also had to have both cases machined for new bearing cup for axle, area as the case is not real strong and the area will crack or distort as bearings wear or turn in case.
