645B Brake Question |
Amos
Topic: 645B Brake QuestionPosted: 08 Jan 2015 at 1:08pm |
I am wondering, as I have to overhaul the entire brake system on my 645, if I can eliminate the valve on the transmission from the hydraulic portion of the brake system and use an air cylinder to disengage the transmission rather than the hydraulic brakes. Doing so would prevent the cross contamination of the brake fluid and transmission oil. Is the spool in this valve easily adaptable to attaching and air cylinder? I don't have my loader in the shop, but I do have to replace all the wheel cylinders as they are leaking and the master cylinders are weeping a bit as well. Just wanting to have the parts here to go at it as opposed to having to find them when it is in the shop and possibly holding up the shop space for a few days is all.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55281 |
Posted: 08 Jan 2015 at 5:51pm |
Look for an air over hydraulic valve. Surpluscenter.com might have 'em...
Amos
Posted: 09 Jan 2015 at 6:03pm |
Good idea Dave, thanks
DiyDave
Posted: 09 Jan 2015 at 6:19pm |
Might also work, with a solenoid, and a brake light switch...
