645 loader wheel bearing
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Topic: 645 loader wheel bearing
    Posted: 16 Oct 2011 at 11:01pm
Found a 645 loader with a bad wheel bearing.  Any idea what is involved in fixing it and the cost if it is just a wheel bearing?
Talked to the owner this morning, sounds like it needs more then a wheel bearing.  He said he was loading topsoil and noticed oil coming out of the cover place on the right side of the rear axle.  I suspect the planetary gears may be toast.  Said that hub had an oil leak and he hadn't checked the oil in a while.  The machine is about 100 miles away in the mountains and it's snowing there currently.  May go look at, may not. He's asking $6,000 for it.  Low hours on the engine and doesn't leak otherwise.  Is it worth the drive to check it out?
Edited by JohnCO - 17 Oct 2011 at 12:10pm
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2011 at 12:37pm
Another thought, I have an older (1965?) 545 with a questionable transmission.  Anyone know if the axles, or at least the planetarys are interchangeable with a 645B?
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2011 at 2:08pm
axles and planetarys likely to be smaller on the 545. They have a narrower track, so the housings will be different. 545 is 2 sizes down from the 645 so all axle stuff is probably lighter.
