645 engine parts
barnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote barnie Quote  Post ReplyReply Direct Link To This Post Topic: 645 engine parts
    Posted: 19 Mar 2023 at 4:33pm
Any one know of a supplier where I could find parts for my 645 Wheel loader with a 3500 engine? Please let me know
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2023 at 5:33pm
What parts do you need
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote barnie Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2023 at 1:29pm
Hi Darrel, Thanks for responding, I am looking for sleeves  with "o" rings and a gasket set for my 645 with a 3500 engine. I did sleeves and pistons about 2 years ago , but for some reason the sleeves became pitted on the outside and eventually water was seeping through. DOnt understand why it happened so quickly but it did . So I have to replace the sleeves.
Thx
Barnie
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2023 at 8:18pm
Flush all the green antifreeze out of everything and put HD diesel red antifreeze in. It's got all the additives baked in. Truck stops will have it as all newer semis use it. Liner pitting is from antifreeze without the proper additives.
Post Options Post Options   Thanks (1) Thanks(1)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2023 at 10:20am
Thx
Barnie
Ok, sorry but I can't help you out with that sort of stuff. I have one 645 parts machine, so have a few used parts, but nothing like what you need. I hope that you can get what you need and get er going.
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote barnie Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2023 at 1:06pm
Thx will do , any commercial name or brand for the red antifreeze?
Post Options Post Options   Thanks (0) Thanks(0)   Quote barnie Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2023 at 1:07pm
Thank Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2023 at 8:15pm
Google it and you'll find plenty
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2023 at 1:59pm
Add a coolant filter to it and check the ph each year
Post Options Post Options   Thanks (0) Thanks(0)   Quote barnie Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2023 at 5:25pm
Will definitely do that, thx . b
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2023 at 10:12pm
when heavy duty diesels went to red antifreeze,the coolant filter went away. It is typically 5yrs-500000 mile then add a packet of conditioner. Truck shop told me to just change it out at that time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote barnie Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2023 at 2:42pm
thx
This page was generated in 0.371 seconds.
