620 oil levels. |
jeff n
Joined: 15 Sep 2009 Location: new providence Points: 70 |
Topic: 620 oil levels.Posted: 10 Jun 2017 at 10:10am |
Hi I just got a 620 and I don't really know where to check the trans / hydraulic oil. I found a plug on top of the rear end but can't find a drain plug.i put a new hydrolic filter on and would like to change the oil as well. Any info would be helpful thanks .
Gary in Texas
Joined: 11 Sep 2009 Location: Burkburnett, TX Points: 630 |
Posted: 11 Jun 2017 at 5:09am |
You have to remove the metal cover from the under side of the rig, runs from the engine to the trans/diff.
Then unhook the electric wire from the temp sending unit and remover the temp sending unit, at the front end of the trans/diff. That is what my books tells me to do to drain it.
Edited by Gary in Texas - 11 Jun 2017 at 5:10am |
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5205 |
Posted: 11 Jun 2017 at 9:17am |
My 720 has a dipstick on the bottom of the square head fill plug on top of the rear end behind the seat.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 11 Jun 2017 at 9:55am |
616 has street ell turned upright on the right side with petcock that is the high leval could depend on early or late 620, still drains in the same place as mentioned above post
jeff n
Posted: 11 Jun 2017 at 12:59pm |
Ok thanks for the help I'll check it out in a few days. Can you still get any books anywhere for this tractor?
Allis Gal
Joined: 11 Sep 2016 Location: Farmington, MO Points: 14 |
Posted: 11 Jun 2017 at 8:10pm |
you can download an operators manual here:
