620 keep mower deck up |
BrianC
Joined: 16 Jun 2011 Location: New York Points: 1619 |
Topic: 620 keep mower deck upPosted: 15 May 2016 at 9:24am |
I want to use the 3pt yet keep the mower deck in the up position.
Is there an official way, or hacked way to do that? |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 15 May 2016 at 9:38am |
Take the deck off. The deck height is controlled by the lift arms via cables, so I do not see any way to keep the deck in the raised position. What kind of 3 point work are you going to be doing? Probably best not to have the deck hanging under the tractor.
farmtoybuilder
Joined: 11 Sep 2009 Location: Dresden,Ohio Points: 1457 |
Posted: 15 May 2016 at 10:44am |
Can be done! Install a small piece chain or strap onto lift points of deck or other spot. and you'll need a bracket on frame of tractor so when you raise mower to pin it in place. Raise mower up and measure- figure out length of chain or strap needed to pin it in up position. Most All compact tractors use them with belly mowers. Do search for mid mount mowers, Kubota's use straps that are on deck and some in lift linkage on B's and L's compacts.
BrianC
Posted: 15 May 2016 at 4:05pm |
Wanted to use the Brinly disk harrow.
I attached it to the JD 318 and got the job done. Would have rather used the 620. I couldn't see an easy strap attach point. Could the foot boards support the weight? Nah. Time to work on the tractor for every implement initiative. |
